Solenoid was the wrong term. I apologize. That's what I get from going by memory.
Look in the EC section of the FSM. On the bottom right of EC-10, you get a very vague description of the throttle opener. That is what prevents the throttle from slamming shut when you are off the gas quickly. Basically, it uses the engine vacuum to keep the butterflies open some to prevent an overly rich condition.
When the 280Z came out, the system that car used is known as the BCDD or boost controlled deceleration device.
Guest
Reply to this topic...
