February 21Feb 21 comment_674735 1 hour ago, Zed Head said: There's an empty hole in 1971, then there's a Nissan factory labeled cigar lighter in 1973 in the exact same spot. About as far from bizarre as a logical person could get, I think. That's what's known as confirmation bias. The "empty hole" was designated for the optional E4100 fog lamp switch, as I have already pointed out. The E4100 fog lamp switch - literally - could not go anywhere else. The design of the switch alone dictates that. 1 hour ago, Zed Head said: They should have put that information in the Owners Manual, instead of just showing an empty hole. Beside that, do you have any documentation describing the optional fog lamp switch? And the fog lamps, which, of course, would need installation also. That would add a lot to the discussion. Much more interesting than a single comment in a forum. The details and official documentation. Sorry for the "single comment in a forum" (hopefully you can't see my eyes rolling....). I'm writing this after you have posted a couple of old threads - active several years before you joined the site - which discussed the factory fog lamps in some detail, with a fair chunk of the posted data coming via Yours Truly. I suggest you spend a little time actually reading and understanding it. There's gold in them thar hills... 51 minutes ago, Zed Head said: Here's a different guy that says the fog lamp option was Japan market only. So if that's correct then Nissan was basically cutting costs by not producing non-Japan market dashes. They just left the spot open with no option for non-Japan market customers to fill it with anything. But he is - of course - mistaken. The other option is that he knows full well that the factory fog lamps were offered in markets other than the Japanese domestic and - get this - he's trying to sell you something. It wouldn't be the first time that somebody stretched the truth a little - or didn't manage to tell the whole truth - when telling us about these cars. Does "Made Expressly For The USA" ring any bells...? Here's a scan of a page from Nissan's 'R-Drive' Export market parts catalogue C-0010R. The components are - just like they were in Japan - listed as 'Option' parts: We could - indeed we have, back in the days when this forum was a little bit more engaged by matters historical than in reading spark plug runes - discuss many other monkey tail appendixes and "mystery" (to some more than others...) holes and fixtures on these cars that are there for a very good reason. As for the factory Fog Lamps, the component parts existed, the wiring was there in the harness to run them, the mounting points were pre-drilled in the front bumper to accept them and the indentation and doubler was there on the dash to accept the switch, from October 1969. Yes, they moved the Cigar Lighter up there later. Doesn't mean that they wanted it there all along. 1 hour ago, Zed Head said: Unless they got creative, with something like an F knob. I think the problem here is that you have come up with a theory and are now engaged in shaping evidence so that it fits. Sorry but your 'F Knob' theory isn't even going to float, let alone fly. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-674735 Share on other sites More sharing options...
February 21Feb 21 comment_674736 10 minutes ago, CanTechZ said: Alan are you able to translate item 17. I'm guessing "optional fog light switch" 🙂 Indeed, it translates as "Fog Lamp Switch" and other factory literature identifies them as being an extra-cost showroom option. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-674736 Share on other sites More sharing options...
February 21Feb 21 comment_674737 17 minutes ago, HS30-H said: Indeed, it translates as "Fog Lamp Switch" and other factory literature identifies them as being an extra-cost showroom option. Thanks Alan, just for fun I tried using the translate feature on google lens. It worked well. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-674737 Share on other sites More sharing options...
Saturday at 02:01 PM3 days Author comment_675830 So... Condensers.None of them are shown on the original wiring diagrams, yet it is clear that some exist. I'm working on some revisions to the wiring diagram and I'd like to put the condensers on it.It seems pretty clear that there should be a condenser mounted on the distributor. And it's connected to the points side of the coil (coil negative) like this:Next, it seems pretty clear there should be a condenser mounted over on the coil itself. Question is... Should it be connected to the coil (+), or the coil (-)? Seems to me that it should be connected to the coil (+), since the condenser mounted on the distributor is already connected to the coil (-):Next, is the voltage regulator and alternator. Here's a pic that shows the condenser at the voltage regulator, but there is no condenser on the alternator itself:But I've seen pics with a condenser mounted right on the back side of the alternator, like this:So, my outstanding questions are:1) To which coil connection (battery side, or points side) does the condenser on the coil make connection to?2) Should there be a condenser on the back of the alternator?And thank you all for the hoovered pics. I'm pretty sure some of them came from members here. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675830 Share on other sites More sharing options...
Saturday at 03:05 PM3 days comment_675831 CO, the condensor on my coil is connected to the + post along with the B/W wire. Also, a condensor is on my alternator as you pictured. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675831 Share on other sites More sharing options...
Sunday at 01:50 AM2 days Author comment_675848 10 hours ago, jfa.series1 said:CO, the condensor on my coil is connected to the + post along with the B/W wire. Also, a condensor is on my alternator as you pictured.Awesome. Thanks for the help. So it sounds like there are supposed to be four condensers:One on the distributor.One over by the coil, attached to coil (+)One on the back of the alternator, andOne by the voltage regulator.Anyone else want to weigh in? Input from people who document pretty much everything? ( @CanTechZ ) Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675848 Share on other sites More sharing options...
Sunday at 02:39 AM2 days comment_675850 Found a picture on BaT. #138 shows a condenser on the back of an alternator.Bring a TrailerNo Reserve: 1972 Datsun 240Z 4-SpeedBid for the chance to own a No Reserve: 1972 Datsun 240Z 4-Speed at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #181,834.Uploading Attachment... Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675850 Share on other sites More sharing options...
Sunday at 12:27 PM2 days Author comment_675857 Thanks Zed. I will add condensers and publish a new revision to the diagram shortly! Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675857 Share on other sites More sharing options...
Yesterday at 11:54 AM1 day comment_675875 On 4/26/2025 at 6:50 PM, Captain Obvious said:Awesome. Thanks for the help. So it sounds like there are supposed to be four condensers:One on the distributor.One over by the coil, attached to coil (+)One on the back of the alternator, andOne by the voltage regulator.Anyone else want to weigh in? Input from people who document pretty much everything? ( @CanTechZ )Hey CO, #6521 did originally have a condenser in all four locations listed above. Funny that two of your four pics above are of my car. The pic above with no condenser on the alternator, was from about 10 years ago when I pulled it to do some engine detailing. Prior to the detailing it did have a condenser there, but it was not connected. At the time I just left if off when I re-assembled alternator. Here's a before & after pic. Mystery solved, Lol. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675875 Share on other sites More sharing options...
Yesterday at 12:31 PM1 day Author comment_675877 33 minutes ago, CanTechZ said:Hey CO, #6521 did originally have a condenser in all four locations listed above. . Here's a before & after pic. Mystery solved, Lol.Awesome. Thanks!!And your prolific use of pics and documentation has helped me on numerous occasions. Keep up the good work!! I'm currently working on a set of carb air cleaner attachment hardware stuff based on a sketch of yours from years ago. 😊 Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675877 Share on other sites More sharing options...
Yesterday at 09:43 PM1 day comment_675899 @Captain Obvious Check out the engine electrical section of the L24 engine FSM for info on the distributor condenser, page EE-28, 29, 30. There is a circuit diagram and other info. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675899 Share on other sites More sharing options...
10 hours ago10 hr Author comment_675902 15 hours ago, CanTechZ said: page EE-28, 29, 30. There is a circuit diagram and other info.Thanks for the help. I have an incomplete version of the 1970 FSM, but I've been through the EE section. It don't think it shows all the condensers.For example, the circuit diagram you posted only showed the condenser mounted on the distributor. They didn't include the one on the coil attached to the positive side (crudely grafted onto the the diagram below):And they didn't show how the tach connects! At least not until 1972, and it was still cryptic then! Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=6#findComment-675902 Share on other sites More sharing options...
