Slam Panel Dimensions (71 240Z)
Broman
I have carefully removed the slam panel from my project car while fixing the carnage inflicted upon the tail-lamp panel by the previous owner.  The removed panel is very straight and has all the spot weld dimples intact.  The only possible  damage to it is that the ends MIGHT have been trimmed during some cutting they did.  I can easily add a bit of sheet metal to the ends if I know the proper length of the original slam panels.
So the ask is this: if you have the original slam panel, can you please measure the exact length in mm at both the top (A) and bottom (B) of the panels.  (It looks like the ends are not cut at 90 degrees.)
