Front Spindle For Investigative Project
Anybody have a front spindle laying around they don't need? I only need one side, and it doesn't matter which side or which year. I just need the part where the hub mounts.
I'm thinking if someone was working on coil-overs and accidentally cut off the tube too short or something? Or if there was a car that was in an accident and the tube is bent? Or someone who couldn't get the gland nut off and the threads are totally ruined?
I have a 3d scan of the front strut and spindle housing if that helps at all. I also have a damaged front passenger you could have but it's still on my parts car and could be a couple weeks before I can get some time to remove it.
LOL! Thanks guys. It's a double secret project that I'm working on.
But seriously, the short story is... I bought a cheap rotor off rock-auto. China's finest. And right out of the box, it's got over .010 runout. I was thinking that if I could figure out a way to fixture it ON a spindle and run it on wheel bearings, I could take a clean-up cut on it and bring it back to running true.
Thanks much! Scan isn't necessary, but your damaged passenger front sounds perfect.
What are the chances that you're not too far from Philadelphia?
  • Who's Online   2 Members, 0 Anonymous, 129 Guests (See full list)
