240SX versus Maxima rear caliper
Patcon
Does anyone know if the 240SX and Maxima rear brake caliper used for rear disc conversion have the same bolt patterns and offsets?
I had one of my Maxima rear calipers torn down in the shop. My dehumidifier went out during that time and it's got a good bit of rust in the bore. The Maxima calipers are not available anywhere. So was wondering if the 240SX caliper was a direct replacement?
I have the 240sx calipers with the the ZCD adapter plates. You can email Matt and he can tell you if the brackets are the same. At one time they sold both conversion kits.
  • Thanks 1
14 hours ago, SteveJ said:
What year Maxima?
Not totally sure. I've had them for a decade at least. Is there a way to tell from the parts? When I searched, I searched based off of the previous swap recommendations for Maxima year
Post a photo of the caliper showing the mounting bracket.
45 minutes ago, Yarb said:
@Patcon Did your Maxima calipers come with the emergency brake actuators?
Yes
52 minutes ago, SteveJ said:
What year were those for?
