February 1Feb 1 comment_673882 Paint can and color code? Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-673882 Share on other sites More sharing options...
February 1Feb 1 Author comment_673885 This is what I used. I initially used an Olive green but it was too light, so I went to Ace hardware and got a darker green. I used the center part of the horn as the 'master' as it was in the best condition. The Camouflage paint is flat, so I added the gloss clear. A thin semi-gloss may be a little bit better replication. I think the green is maybe a bit on the glossy side, but they do look pretty doggone close to the original. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-673885 Share on other sites More sharing options...
February 1Feb 1 comment_673909 They will probably flatten a little with time Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-673909 Share on other sites More sharing options...
February 8Feb 8 Author comment_674291 The body shop finally had room availabe so we brought the car and all the panels down to the shop. The plan is to media blast next week and then determine what panels will need to be replaced. Got the Block and Head back from the machine shop today. Both look great and nicely done. The block only needed a hone which is good, so we can stick with the original stock pistons and just get new rings. Bearings will be replaced with new stock rod and crank bearings. Oil galleys were cleaned and oil filter check valve and filter screen replaced. The head had just one bad valve and all of the intake valve seats were replaced with the modern 'bronze' seats. Valve guides were replaced. The exhaust valve seats had been replaced during previous machine work. I spent a little time sorting some of the plated hardware putting some of the more common parts in bags. This will help things to move along a bit quicker during assembly time. Pics are below Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-674291 Share on other sites More sharing options...
February 8Feb 8 comment_674293 I really struggle with sorting the hardware. I just don't know it well enough anymore Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-674293 Share on other sites More sharing options...
Sunday at 11:25 PM2 days Author comment_675397 I have been delinquent in posting updates, but finally have a little time so here goes. I will break this up into several posts so the pictures won't be overwhelming.It took almost 5 weeks to get the engine parts from Motorsports, but once they arrrived it gave me all the hardware I needed to finish the engine. The shipment was delayed for the stock piston rings. The motor went together pretty smoothly with no hiccups. The only item that was odd, and I'm guessing it's an early car item, is that the timing chain did not have the two timing links, 42 links apart. There was just one bright link and it actually had a clip feature on it so that it could be easily removed. Can't say I have seen that before. I did not take a pic of it, but may show that in the future. Pics of the engine are below. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675397 Share on other sites More sharing options...
Sunday at 11:27 PM2 days Author comment_675398 I have two 2400 valve covers, one from the original motor and one that the owner sent. I was not happy with the painted valve cover, although it looks pretty, as it would get dinged by the ZCON judges as not the original finish. Also, it's not the original finish. So, I just decided to clean up the original valve cover. I am much happier with that. Looks much better. Pics below Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675398 Share on other sites More sharing options...
Sunday at 11:34 PM2 days Author comment_675399 The body is now at the weld shop and the replacement panels from KF Vintage have arrived. The welder, Larry, said the panels were very good quality and nice thickness. Panels are now being installed. Pics are below.Work is being done by L&L Restomods.https://www.llrestomods.com/ Edited Monday at 12:15 AM2 days by motorman7 Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675399 Share on other sites More sharing options...
Sunday at 11:41 PM2 days Author comment_675400 I have been pre-assembling some of the suspension parts. Looking forward to actually puttling these on the body. The owner sent me two radios to check for operation. One produces sound but the seek is slow, so I will clean that one up. The other operated nicely, but couldn't find a station. Both had the same antenna set-up, so not sure what's up with that one. 20250222_125123.mp4 Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675400 Share on other sites More sharing options...
Sunday at 11:45 PM2 days Author comment_675401 Currently I am working on cleaning up the electrical harnesses. New Connector blocks and terminals from Vintage Connections came in last week. Harness pics are below. The last one is the cleaned up section. Also looks like the ID tags are in good shape and salvagable. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675401 Share on other sites More sharing options...
Monday at 12:00 AM2 days Author comment_675402 I have two fuel pumps, the one that came with the car and one sent by the owner. The one that came with the car looks like it had the cap replaced for some reason. The base looks like the original Nikki, but the cover is an Ampco. I cleaned up the original and will go with that. If anyone has a Nikki top cover, please contact me. Thanks Edited Monday at 12:12 AM2 days by motorman7 Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675402 Share on other sites More sharing options...
Monday at 12:04 AM2 days Author comment_675403 The exhaust manifold will be a bit of a project. I don't beleive that the air galley will be salvagable as the attach fittings are pretty rusted onto the manifold. I will soak these in rust penetrant for a couple more days, but most likely I will need to cut off the air galley, remove the fittings and re-tap the holes. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=5#findComment-675403 Share on other sites More sharing options...
