March 24Mar 24 comment_675406 I would try an induction heater on the manifold and flare nut wrenches. I would probably heat it, soak it, heat it, soak it, then heat it and try to unthread them. I have gotten things apart with my induction heater I thought would never come apart!! Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675406 Share on other sites More sharing options...
March 24Mar 24 Author comment_675408 That seems like the best approach, but they are a little pricey. I saw that you used one on the intake manifold tube fitting and was intrigued. I've used a torch and ice cubes in the past, but it was not very effective on the manifold because of its size I think. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675408 Share on other sites More sharing options...
March 24Mar 24 comment_675411 9 hours ago, Patcon said:I would try an induction heater on the manifold and flare nut wrenches. I would probably heat it, soak it, heat it, soak it, then heat it and try to unthread them. I have gotten things apart with my induction heater I thought would never come apart!!I did something similar on mine a few months ago but with a blow torch:Heat till red hot around the manifold, cool the threads a little with pb blaster, little pressure on the threads with wrench. Repeat for about two hours until all were loose. It caught fire several times, but I did this outside surrounded by snow. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675411 Share on other sites More sharing options...
March 24Mar 24 comment_675414 @motorman7 I think I paid about $150 for mine on Amazon Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675414 Share on other sites More sharing options...
March 26Mar 26 comment_675429 Looks like about 80k Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675429 Share on other sites More sharing options...
March 26Mar 26 Author comment_675430 I tried my MAPP Torch and it was not even close to getting the exhaust manifold red, so I think I will pop for the Induction Heater. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675430 Share on other sites More sharing options...
March 26Mar 26 comment_675431 19 minutes ago, motorman7 said:I tried my MAPP Torch and it was not even close to getting the exhaust manifold red, so I think I will pop for the Induction Heater.MAPP gas isn't MAPP gas anymore. (https://en.wikipedia.org/wiki/MAPP_gas#:~:text=MAPP%20gas%20was%20widely%20regarded,America%20that%20still%20manufactured%20it.)My induction heater works nicely, especially in a tight spot. Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675431 Share on other sites More sharing options...
March 26Mar 26 comment_675432 Where to start1- Fasteners for air pump bracket to engine should be engine blue ditto alt mount fasteners2 - Only right side motor mount bracket should be black - left should be blue3 - Timing pointer should be clear not yellow ditto for the plate at front of cylinder head4 - Freestanding female spade connectors should not have the lock tabNO CHARGE for the above but if you want a Gold Medallion in the stock 240 class I charge $500.00/day plus expenses Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675432 Share on other sites More sharing options...
March 26Mar 26 Author comment_675437 2 hours ago, zspert said:Where to start1- Fasteners for air pump bracket to engine should be engine blue ditto alt mount fasteners2 - Only right side motor mount bracket should be black - left should be blue3 - Timing pointer should be clear not yellow ditto for the plate at front of cylinder head4 - Freestanding female spade connectors should not have the lock tabNO CHARGE for the above but if you want a Gold Medallion in the stock 240 class I charge $500.00/day plus expensesI'll pass. You are mistaken on items 1 and 2 so you already have discredited yourself. If you care to belabor the point, you can refer to the earlier pictures here which show you are incorrect. If you doubt the authernticity of this motor, I can show you my personal vehicle which has been in the family for 55 years and is well documented showing the same thing. Edited March 26Mar 26 by motorman7 Link to comment https://www.classiczcars.com/forums/topic/69151-sn-00042-restoration-the-older-twin/?&page=6#findComment-675437 Share on other sites More sharing options...
