Patcon Posted Sunday at 11:34 PM Share #1 Posted Sunday at 11:34 PM I am exploring making a Euro balance tube out of this balance tube I got some new plugs for the end of the tube and I have a piece of 3/8" rebar to try to knock the plug out. Then I will trim off the extra lumps and take it to the welding shop that just recently TIG'd up Cody's exhaust. More to come... Link to comment Share on other sites More sharing options...
dutchzcarguy Posted 17 hours ago Share #2 Posted 17 hours ago Here, some euro inlet pic's 1 Link to comment Share on other sites More sharing options...
billgtp Posted 12 hours ago Share #3 Posted 12 hours ago I did the same on balance tube for my 71. Grind the lumps off and had it welded up 1 Link to comment Share on other sites More sharing options...
KenFirch Posted 10 hours ago Share #4 Posted 10 hours ago Go all the way and remove the shaft mounts too, by using a throttle cable. 1 Link to comment Share on other sites More sharing options...
240dkw Posted 6 hours ago Share #5 Posted 6 hours ago I have done a few, some with the brake vacuum connection on the end and some with it on the top. Once you weld up the holes, to make it look good you have to go with the polished look and if you fill material is not close to the same alloy as the tube you will always see them as they have a different shine. 1 Link to comment Share on other sites More sharing options...
240dkw Posted 6 hours ago Share #6 Posted 6 hours ago By the way, all of the ones I made are based on the early non-emission style not the euro style. 1 Link to comment Share on other sites More sharing options...
Patcon Posted 34 minutes ago Author Share #7 Posted 34 minutes ago 6 hours ago, 240dkw said: By the way, all of the ones I made are based on the early non-emission style not the euro style. Differences? Link to comment Share on other sites More sharing options...
