Posted December 2, 2024Dec 2 comment_671953 Hello everyone At the beginning of November I started the restoration of my 76' 280z. The body is currently getting fixed and painted, engine is being rebuilt and I took on the task of rewiring the dash for the new gauges. My plan is to use the wires required from the original dash harness while getting rid of the ones I don't. Here is where the problem(s) start. I have a FSM and a colored wiring diagram but to be honest I'm having a hard time figuring out what wire does what. I started with the speedometer, which in the FSM states has 7 wires (one spare pin). Mine has all eight used. The connector pins out as follows: The connector is as follows: Red Red/white Green/white Green/yellow Red/Blue Black Green Green/red I know that the green/white and red/blue are the dash lights - not sure which one is power and which one is ground - and black is ground. I'm also almost positive that the red is your 12V switched from the fuse panel. All the other ones I'm at a loss for. Could someone chime and help? Thank you Jan Edited December 2, 2024Dec 2 by Pomorza Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/ Share on other sites More sharing options...
December 2, 2024Dec 2 comment_671954 22 minutes ago, Pomorza said: Hello everyone At the beginning of November I started the restoration of my 76' 280z. The body is currently getting fixed and painted, engine is being rebuilt and I took on the task of rewiring the dash for the new gauges. My plan is to use the wires required from the original dash harness while getting rid of the ones I don't. Here is where the problem(s) start. I have a FSM and a colored wiring diagram but to be honest I'm having a hard time figuring out what wire does what. I started with the speedometer, which in the FSM states has 7 wires (one spare pin). Mine has all eight used. The connector pins out as follows: The connector is as follows: Red Red/white Green/white Green/yellow Red/Blue Black Green Green/red I know that the green/white and red/blue are the dash lights - not sure which one is power and which one is ground - and black is ground. I'm also almost positive that the red is your 12V switched from the fuse panel. All the other ones I'm at a loss for. Could someone chime and help? Thank you Jan Green (12VDC+) and green/yellow are for the brake warning light. Red and red/white are for the high beam indicator. (Right headlight circuit). Green/white is 12VDC+ for gauge lights. Red/blue goes to the rheostat (dimmer). Green/red (Yellow in the dash harness) goes to the BCDD cut solenoid. Black is ground. Edited December 2, 2024Dec 2 by SteveJ Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-671954 Share on other sites More sharing options...
December 2, 2024Dec 2 Author comment_671955 Quote Green (12VDC+) and green/yellow are for the brake warning light. Red and red/white are for the high beam indicator. (Right headlight circuit). Green/white is 12VDC+ for gauge lights. Red/blue goes to the rheostat (dimmer). Green/red (Yellow in the dash harness) goes to the BCDD cut solenoid. Black is ground. Steve. Thank you sir. How would I go about wiring the high beam indicator on my new gauge if its only one wire - should I just put the red + red/white together? Cheers Jan Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-671955 Share on other sites More sharing options...
December 2, 2024Dec 2 comment_671991 6 hours ago, Pomorza said: Steve. Thank you sir. How would I go about wiring the high beam indicator on my new gauge if its only one wire - should I just put the red + red/white together? Cheers Jan Considering you haven't said what gauges you are using, there is no way to tell for certain. Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-671991 Share on other sites More sharing options...
December 2, 2024Dec 2 Author comment_671999 Quote Considering you haven't said what gauges you are using, there is no way to tell for certain. Speed hut Z series. The speedometer has both the high beam indicator (one wire) and the turn signals (one wire each). Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-671999 Share on other sites More sharing options...
December 3, 2024Dec 3 comment_672006 Did they not come with any form of a schematic? Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672006 Share on other sites More sharing options...
December 3, 2024Dec 3 comment_672020 14 hours ago, Pomorza said: Speed hut Z series. The speedometer has both the high beam indicator (one wire) and the turn signals (one wire each). I was thinking you were going that way. What I did for someone else was wire a relay as described below. (See https://fiddlingwithzcars.wordpress.com/2012/12/22/relays-simplified/ for a reference on the pin numbers.) Red - Wire to pins 86 and 87. Red/white - Wire to pin 85. Wire pin 30 to the high beam indicator in the gauge. Here's a link to relays on Amazon: https://www.amazon.com/awlbed-Replacements-Waterproof-Automotive-Accessories/dp/B0CP1ZYWJZ 10 hours ago, Yarb said: Did they not come with any form of a schematic? They do, and the schematic is online, too. However, Speedhut never had the wiring modified to be plug-and-play for the Z. Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672020 Share on other sites More sharing options...
December 3, 2024Dec 3 Author comment_672029 Quote I was thinking you were going that way. What I did for someone else was wire a relay as described below. (See https://fiddlingwithzcars.wordpress.com/2012/12/22/relays-simplified/ for a reference on the pin numbers.) Red - Wire to pins 86 and 87. Red/white - Wire to pin 85. Wire pin 30 to the high beam indicator in the gauge. Here's a link to relays on Amazon: https://www.amazon.com/awlbed-Replacements-Waterproof-Automotive-Accessories/dp/B0CP1ZYWJZ I was worried that this would require more than just plug and play. Simple enough though, I was planning on adding relays to the headlights anyway. Just to make sure I have everything correct here. From the Speedhut schematic 1. Red (pwr) -> Green power wire on Z car (12V) 2. Black (gnd) -> black on z car (ground) 3. White (lights) -> green/white on Z car (dash lights)* 4. Blue (high beam) -> pin 30 on said relay 5. Green/orange (RTS) -> white/black on Z car (12v turn sign right) 6. green/red (LTS) -> white/red Z car(12v turn sig. left) *Or do the dash lights also have to go through a relay since there are two wires. I don't plan on using the dimmer (was actually planning on removing it all together). All the other gauges are just three wire + sensors which I can figure out pretty easily. Thank you for all the help! Cheers Jan Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672029 Share on other sites More sharing options...
December 3, 2024Dec 3 comment_672030 IMHO, Save time and run LED headlights and buy the housings. @SteveJ has a complete list on the forum for everything you need to convert the entire car over to led. Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672030 Share on other sites More sharing options...
December 3, 2024Dec 3 comment_672032 2 hours ago, Pomorza said: I was worried that this would require more than just plug and play. Simple enough though, I was planning on adding relays to the headlights anyway. Just to make sure I have everything correct here. From the Speedhut schematic 1. Red (pwr) -> Green power wire on Z car (12V) - That will work 2. Black (gnd) -> black on z car (ground) - That will work 3. White (lights) -> green/white on Z car (dash lights)* - That should work. Red/blue does not need to be connected. 4. Blue (high beam) -> pin 30 on said relay - Still going strong 5. Green/orange (RTS) -> white/black on Z car (12v turn sign right) - That should be green/black 6. green/red (LTS) -> white/red Z car(12v turn sig. left) - Yes *Or do the dash lights also have to go through a relay since there are two wires. I don't plan on using the dimmer (was actually planning on removing it all together). All the other gauges are just three wire + sensors which I can figure out pretty easily. Thank you for all the help! Cheers Jan Now if you haven't cut the connectors off your dash harness, you can de-pin the wires you need, and pin them into new connectors. Then you can put female connectors on your gauges to make it where you can plug and unplug the gauges from the harness. Here's a source for the YPC connectors. You have to buy the pins separately.https://www.hi-1000ec.com/product/1135 If you want to go down that path, I can advise you. I attached the latest update to my LED light list. Note that sometimes bulbs disappear from Amazon. I usually find out when I hear from someone trying to buy from the list. Here is a suggested source for the H4 housings: *Link removed by SteveJ* Cheaper option: https://tinyurl.com/mr66wfd2 I don't use the relay wiring kit that comes with it, but you could repurpose one of the relays for your high beam. LED bulb list 2024-12-03.txt Edited December 3, 2024Dec 3 by SteveJ Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672032 Share on other sites More sharing options...
December 3, 2024Dec 3 comment_672033 Don’t know if it’s just me, the last couple of days eBay links are erroring out on this site. Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672033 Share on other sites More sharing options...
December 3, 2024Dec 3 comment_672034 22 minutes ago, Yarb said: Don’t know if it’s just me, the last couple of days eBay links are erroring out on this site. How about a non-ebay link? https://www.google.com/search?q=81110-60P70&sca_esv=427fd9fc564ca397&sxsrf=ADLYWILMGej8UneOeVTFsc1VBYcwYqWibw%3A1733268603748&source=hp&ei=e5RPZ9OcK_iIwbkPqPbayAQ&iflsig=AL9hbdgAAAAAZ0-ii2PzxIsi6K-RZX6yIH85AzsXThiC&ved=0ahUKEwiTxrLb4IyKAxV4RDABHSi7FkkQ4dUDCBo&uact=5&oq=81110-60P70&gs_lp=Egdnd3Mtd2l6Igs4MTExMC02MFA3MDIEECMYJzIIEAAYgAQYogQyBRAAGO8FMgUQABjvBTIIEAAYgAQYogQyBRAAGO8FSIVeUABY_ldwAXgAkAEAmAFfoAG6AaoBATK4AQPIAQD4AQL4AQGYAgKgAmCoAgrCAgcQIxgnGOoCmAMDkgcBMqAH1AQ&sclient=gws-wiz Edited December 3, 2024Dec 3 by SteveJ Link to comment https://www.classiczcars.com/forums/topic/69178-wire-colors-and-function/#findComment-672034 Share on other sites More sharing options...
