Mustache Bar
texasz
Someone just asked me if I had "...a mustache bar for a 240..."
Now as I recall the mustache bar is specific to the diff, either an R180 or an R200 and not the model Z. Is this correct? If not then what models had the same mustache bar as the 240, that is if any others were the same?
Mustache bars are specific to the diff used. But, you can run into trouble with the 280 in the US as they used both the 180 and 200 during its model run from 75-78....
The 200 bar has a different spacing (and size of mounting bolt if I remember right), for the rear diff mounting bolts. It is possible to make a 180 bar work with the 200, but you would have to slot the holes or weld them up and then re-drill them....
Thanx guys!! The person clarified what their needs are. He wants to put an R180 3.36 on his '76 280Z (not sure why but hey, it's his car). So in this case he does need the R180 bar from a 240 or 260.
  • Who's Online   0 Members, 0 Anonymous, 373 Guests (See full list)
