Recently Browsing 0
I have another thread documenting the Wilwood rear brake install I did. In this thread I am going to document the front disc install. I am using the Wilwood Dynalights. The discs are the same front and back but the swept area of the pad is different. The front discs have also been drilled to match the bolt pattern of the hub.
The new front calipers are very light. All aluminum. Here it is compared to the Toyota caliper
Here is the starting point for my front brakes. I did have the Toyota caliper on and the dust shields have been trimmed
Hub has to come off
Then the dust shield needs to come off
Then remove the bolts from the hub and swap rotors
A brass hammer might be helpful to get every thing lined up and seated
Everything on the Wilwoods seems to be SAE so there are two different bolts in the kit. The two metric bolts for bolting the adapter to the strut ears and the two SAE bolts for attaching the caliper to the adapter plate
The Silvermine logo appears to face outward on these adapters
When I first bolted this side up, it bound up against the rotor. So I had to add some washers to space it back a little bit. The metric bolts have plenty of length so that wasn't an issue. I didn't have any pretty washers to use so I used these.
Also I had to trim the upper washer because the OD was too large to center over the hole
All together
It is easier to add the washers when installing the adapter if you know you'll need to
I guess you could install it with washers and you don't need them you can drop them out. It's a lot easier to drop them out than get them in and centered over the bolts.
This install is on an early series one car. Your mileage might vary...
https://www.classiczcars.com/forums/topic/69186-silvermine-wilwood-dynalight-front-brake-upgrade/Share on other sites
