Cannot get quarter windows to seat into position after new weatherstripping
fusion
I have a 1976 280z that I am just finishing up with basically a full restoration.  I reassembled the quarter windows with all new weatherstrip from Precision.   I cannot get them to seat far enough back to get the window frame screw holes to line up with the body holes.  I was able to get the bottom 2 started after extreme effort but the tops are still 1/4" or more away and the door won't close with where it's sitting right now as the door interferes with the vertical seal on the quarter window.
I lubed up the seals with silicone spray and sprayed the body area with Windex prior to starting.  I was absolutely pushing with all my might while having a helper in the hatch to just barely get the bottom screws started.  If it matters, temperature in my garage was about 60*F.
Even as it sits with the bottom screws in, the door won't close.  How tight is the door/vertical seal supposed to fit together when closing?
The entire window assembly needs to move back at least the width of this gap, maybe more:
I'm wondering if the Precision outer weatherstripping is too stiff?  It was brand new.  Maybe I should have glued the first part and stretched it while gluing to thin the bulk out some?
Maybe I should just leave it partially installed in the opening as it is now and try pushing again in a few days to see if the new weatherstripping has 'broken in' a bit?
I don't think I can push any harder without the risk of damaging something.
Looking for advice.
Thanks
I seem to recall a thread where a member used a block and tackle or some such to suck those suckers into place. Complete battle. Could NOT get the screws in any other way. i have fought this battle and given up and trimmed the seals away then used some glass sealant to form a lovely “looking” seal against the body.  Or leave the stock seal, clean it up, then use the filler technique to get a moisture seal.
Just another battle with ill fitting aftermarket weatherstripping.
That might be me, I did this Rube Goldberg approach solo in my garage. I installed a couple of large hooks (bike hangers) in the base plate of the garage wall, ran a large ratchet strap from one hook, thru the hatch opening, around the window, back to the second hook - ratchet on this end. Easy on the pressure to gently pull and hold the window into position to get the screws lined up. Lube the new seal a bit to allow it slide against the body. East peasy!!!
  • Like 3
  • Thanks 1
I also used a straight pick in the screw holes to help pry it into place and line up the screw holes. They can be difficult to get in properly. I would use some of the Precision sealant lube. Do not use silicone on painted surfaces. It's is very difficult to get off later if paint work needs to be done.
I was finally able to get it.  I have a roll bar in the car and was able to use that with a clamp to draw the window back.  Wow, what a pain.
Now that it's done, I'm having a bit of interference with the weatherstrip on the top of the door and the vertical weatherstrip on the front of the quarter window.  How is this supposed to work?
  • Who's Online   1 Member, 0 Anonymous, 527 Guests (See full list)
