Regarding the deep (full-size) spare tire tubs, I have seen two differences.
1) Some have one drain hole (fwd) and some have 2 (fwd and aft).
2) Some have what looks like a heat shielded welded to the side next to muffler.
The question: what is the date of these changes?  Before I weld in my salvaged tire tub I wanna make sure I have the correct one.
  On 1/10/2025 at 7:06 PM, Monztr said:
What year is yours?
May 1971.
I dug around and found the original, old rusted-out one from may car...one drain hole.  So sometime between 5/71 and 7/76 they added a second drain hole.
Also, my 5/71 tub did NOT have a heat-shield on the side.
Here's a pic of a later tub that has the second (rear) drain hole and a heat shield.  I wonder when this change was made.
