Email logins are now active ×
Mechanical Fuel Pump - Slow return to start position
1971 240z: I removed the valve cover and manually operated the fuel pump arm. When I release the arm, it sends fuel to the carburetors. I noticed that it takes a noticeable amount of time for the arm to return to its starting position on the cam lobe. During this return, the pressure has a max of 6 psi. I can confirm that the return line produces a visible spray of fuel into a glass jar. Once the spray from the return line diminishes and  I see the pressure drop below 3 psi, the pump arm is ready for another cycle.
With the engine NOT running, should I assume this is normal behavior?
My concern is the time delay. If this delay remains during engine operation, the fuel pump arm would float and never have a full stroke. That's assuming it is supposed to always have a full stroke 100% of the time.
Perhaps you need a new return spring? Make sure there is not a build up of gunk around the lever/ return spring area. When I was checking my pump (removed from the car) it would return quickly with an audible click. I also have an original '71 Nikki pump. My luck with after market pumps has been pretty bad, the majority of them are junk.
I purchased a new fuel pump from a different manufacturer. It has a much firmer and shorter arm throw for a complete pump cycle. I manually measured the difference between the two, and the new pump has a 1/2-inch shorter throw.  It's behaving more like I expected. It quickly returns to the start position without much delay, and I get approx. 5 lbs of pressure from it. I'll agree with Zpenman at this point and chalk it up to poor manufacturing of the original replacement part.
Thanks, everyone.
