January 22Jan 22 comment_673574 On 1/14/2025 at 1:20 PM, Captain Obvious said: Are you able to see the fuel pressure gauge WHILE you are driving? For the time that you're spending on the problem it might be worth the length of hose and the clamps to get that real-time data. Borrowed this from a Corvette forum. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673574 Share on other sites More sharing options...
January 22Jan 22 Author comment_673575 On 1/22/2025 at 8:30 PM, Zed Head said: For the time that you're spending on the problem it might be worth the length of hose and the clamps to get that real-time data. Borrowed this from a Corvette forum. Ya, I'll give that a shot this weekend I'm thinking Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673575 Share on other sites More sharing options...
January 22Jan 22 comment_673576 On 1/13/2025 at 1:46 AM, Captain Obvious said: I wonder if maybe you've got air in that line which somehow can't get purged out because of the routing. Not sure if that's a thing, but maybe something to think about and look into? Maybe it's sucking air through the inlet side. Any signs of seepage back there? A tiny liquid leak could be a big air leak. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673576 Share on other sites More sharing options...
January 22Jan 22 Author comment_673577 On 1/22/2025 at 8:33 PM, Zed Head said: Maybe it's sucking air through the inlet side. Any signs of seepage back there? A tiny liquid leak could be a big air leak. I'll give it another look, but nothing as of now and you can't smell gas. We didn't see any leaks when we were under the car with the pressure gauge over the weekend. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673577 Share on other sites More sharing options...
January 23Jan 23 comment_673578 There are many connections on the harness that need addressing. AFM etc. Are you doing the work yourself or having it done. That makes a huge difference in moving forwards as far as cost goes and I truly understand. Looking back and have known what I have learned fighting mine for a very long time I should have done that first. You also have the sub-harness that others were mentioning. Those connections are critical temp wise where the ECU determines the richness. Replaced that harness as well although you can fabricate that yourself as well. All this will give you a peace of mind moving forward. I wish you luck. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673578 Share on other sites More sharing options...
January 23Jan 23 Author comment_673579 On 1/23/2025 at 4:02 AM, Yarb said: There are many connections on the harness that need addressing. AFM etc. Are you doing the work yourself or having it done. That makes a huge difference in moving forwards as far as cost goes and I truly understand. Looking back and have known what I have learned fighting mine for a very long time I should have done that first. You also have the sub-harness that others were mentioning. Those connections are critical temp wise where the ECU determines the richness. Replaced that harness as well although you can fabricate that yourself as well. All this will give you a peace of mind moving forward. I wish you luck. Thanks. All the sensors on the front and their connections are new. It really doesn't make sense to me that the fuel line blowing can suddenly make a car running great suddenly have an issue with the EFI connectors but stranger things have happened. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673579 Share on other sites More sharing options...
January 23Jan 23 Author comment_673580 On 1/22/2025 at 8:30 PM, Zed Head said: For the time that you're spending on the problem it might be worth the length of hose and the clamps to get that real-time data. Borrowed this from a Corvette forum. This is a dumb question, but I'm going to ask it anyway. Wouldn't holding the pedal at 3k in my garage be the same as driving around or does the pump work harder when the car is under load? Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673580 Share on other sites More sharing options...
January 23Jan 23 comment_673581 On 1/23/2025 at 4:25 AM, chaseincats said: Wouldn't holding the pedal at 3k in my garage be the same as driving around or does the pump work harder when the car is under load? It's not the same. It takes a lot less fuel sitting still at 3K sitting than driving around. The load is so much lower. Try this... Sit in the driver's seat and with the engine running, push the gas pedal down until the engine is spinning at 3K. Note how little pedal it takes to do that. Way less pedal to do that than do drive around under load. Hope you can make some headway with this issue. I'm sure you're tired of dealing with it. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673581 Share on other sites More sharing options...
January 23Jan 23 comment_673582 These are important. Pull them apart and shine the connections up, maybe some dialectic grease too. http://www.atlanticz.ca/zclub/techtips/runningrich/bullets.jpg Edited January 23Jan 23 by siteunseen Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673582 Share on other sites More sharing options...
January 23Jan 23 Author comment_673583 On 1/23/2025 at 3:14 PM, siteunseen said: These are important. Pull them apart and shine the connections up, maybe some dialectic grease too. http://www.atlanticz.ca/zclub/techtips/runningrich/bullets.jpg i snipped those off and soldered on new connectors there a few years back 😞. it definitely did make a huge difference though. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673583 Share on other sites More sharing options...
January 23Jan 23 comment_673584 On 1/22/2025 at 8:30 PM, Zed Head said: For the time that you're spending on the problem it might be worth the length of hose and the clamps to get that real-time data. Borrowed this from a Corvette forum. This is easy to do if you already have a gauge spliced in. I put about 4ft of 5/16 hose between the fitting and the gauge. Unscrewed the gauge from the fitting, put the hose on the fitting with a good clamp, shoved the gauge into the other end of the hose and put on another EFI clamp. Zip tied it to driver's wiper arm and drove around for a day or two. Put the PSI numbers on here. Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673584 Share on other sites More sharing options...
January 23Jan 23 Author comment_673585 On 1/23/2025 at 4:33 PM, siteunseen said: This is easy to do if you already have a gauge spliced in. I put about 4ft of 5/16 hose between the fitting and the gauge. Unscrewed the gauge from the fitting, put the hose on the fitting with a good clamp, shoved the gauge into the other end of the hose and put on another EFI clamp. Zip tied it to driver's wiper arm and drove around for a day or two. Put the PSI numbers on here. That's a great idea since that is currently my exact setup. I'll give that a try this weekend - thanks for that Link to comment https://www.classiczcars.com/forums/topic/69214-tank-to-pump-hose-routing/?&page=5#findComment-673585 Share on other sites More sharing options...
