5 hours ago, Zed Head said:
That is a "colder" than spec spark plug. Might be why the electrode on 1, 2, and 5 are dirty. The white ash on 3, 4, and 6 looks pretty good, but still on the cold side.
Have you adjusted the valve lash? It looks like you have some cylinder imbalance.
https://www.ngk.com.au/technical_info/heat-range/
I adjusted the valves about a year and a half ago, but that's a good point - I'll give it a look and report back.
Regarding the spark plugs, I can't seem to find any bpr6es on amazon for the 78 head thread. Would bpr5es work or would that be too hot a plug?
Interesting article - thanks!
EDIT: I believe we ended up going with colder spark plugs since we're running the engine learner than usual (14.7 cruise) to guard against pinging.
EDIT 2: I just confirmed all of the valves are still in-spec
Edited by chaseincats
