The rubber stopper on the u bolt saddle is deteriorated and falling off.  Any suggestions on a modification?  Thinking about a rubber stopper threaded into the saddle or some time of adhesive to attach it.  Thanks for any help.  Also just got the steering shaft u joints in the mail and have prepped the bottom yokes for paint and installing new joints.  The 4 stake marks on each ear came out nicely with a Dremel tool.  Waiting for a bit warmer weather to do the painting.  Thanks, John.
https://www.classiczcars.com/forums/topic/69231-78-280z-rack-stopper-rubber/
Thanks for the replies.  The actual rack bushings I already have.  In fact I have all the poly bushings for the whole resurrection project already purchased from ENERGY SUSPENSION,  ready for reassembly.  PATCON shows the exact piece I am searching for, or maybe modifying the one we have with a new rubber bumper.  I will check out the link he provided, though it was labeled out of stock.  Thanks again, John-Lugoff, SC.
Thanks for the info.  I will be checking into that part for pricing and shipping costs.  Exactly what I am looking for even though I am not sure of how important it may be for the steering rack, but apparently the Z engineers considered it necessary.  Thanks again, John-Lugoff, SC.
A prior discussion long ago about the intention of this part led us to believe (guess?) that it is a safety item in the case of a crash, to prevent the rack from rotating to preserve steering control by preventing the steering shaft u-joint angle from locking due to excessive angle. Or if the bushings wear out or fall out etc. Can’t imagine what else it might be for. I don’t think there is a force tendency to rotate the rack during normal driving. The tie rod ends rotate freely. Just me thinking out loud. Well, typing out loud.
I’m likely to have a well used example attached to a old steering rack around here someplace if the need arises.
Edited by zKars
Thanks for the responses.  The u bolt simply is tightened to the rack so that the little rubber bumper, the piece that is bad on my project, hits up against the crossmember.  There is actually a clean spot on my crossmember where that rubber bumper touched.  The rest of the crossmember has it's fair share of grease and road grime.  I am still waiting on a reply from 240ZRUBBERPARTS on obtaining one of their u bolt saddles with the attached rubber.  Hope you all have a good day, John, Lugoff, SC.
