Posted February 5Feb 5 comment_674145 Hello, I have triple Weber dcoe 40 at the moment. I plan on going fuel injection itb setup. My question is will the triple webers canon intake manifold bolt up and work with Jenvey ITBs (40s) or ITBs in general or is another manifold required? Link to comment https://www.classiczcars.com/forums/topic/69238-will-a-triple-weber-canon-intake-work-with-jenvey-itbs/ Share on other sites More sharing options...
February 5Feb 5 comment_674150 Not being an expert, I’m sure someone has tried it and you might find an answer on HybridZ’s site. Link to comment https://www.classiczcars.com/forums/topic/69238-will-a-triple-weber-canon-intake-work-with-jenvey-itbs/#findComment-674150 Share on other sites More sharing options...
February 6Feb 6 comment_674162 I believe the Jenvey's will bolt right up but not positive. You could email Redline and ask. I believe they sell Jenvey's Link to comment https://www.classiczcars.com/forums/topic/69238-will-a-triple-weber-canon-intake-work-with-jenvey-itbs/#findComment-674162 Share on other sites More sharing options...
February 6Feb 6 Author comment_674164 On 2/6/2025 at 2:37 AM, Patcon said: I believe the Jenvey's will bolt right up but not positive. You could email Redline and ask. I believe they sell Jenvey's Good idea, I will send get in contact with them. Thanks! Link to comment https://www.classiczcars.com/forums/topic/69238-will-a-triple-weber-canon-intake-work-with-jenvey-itbs/#findComment-674164 Share on other sites More sharing options...
February 6Feb 6 comment_674167 The stud pattern on the jenvey 40 and 45 itbs is the same as the 40/45 dcoe carbs. Thats the point. The itbs come in 3 lengths I think, and I suppose it is possible that the longest ones might be too long. You should be able to measure it up on your car. Link to comment https://www.classiczcars.com/forums/topic/69238-will-a-triple-weber-canon-intake-work-with-jenvey-itbs/#findComment-674167 Share on other sites More sharing options...
February 7Feb 7 Author comment_674272 On 2/6/2025 at 2:48 PM, jonbill said: The stud pattern on the jenvey 40 and 45 itbs is the same as the 40/45 dcoe carbs. Thats the point. The itbs come in 3 lengths I think, and I suppose it is possible that the longest ones might be too long. You should be able to measure it up on your car. Thank you, just confirmed today that the itbs will bolt right up to the canon manifold no problem. Wanted to use this manifold since the manifold grabs vacuum from from every port so I can get a better MAP reading for tuning. Link to comment https://www.classiczcars.com/forums/topic/69238-will-a-triple-weber-canon-intake-work-with-jenvey-itbs/#findComment-674272 Share on other sites More sharing options...
