Posted February 11Feb 11 comment_674450 I need to get my engine bay in order and tidy and would like recommentations on high temperature resisting nylon or cloth sheath. Anyone? Link to comment https://www.classiczcars.com/forums/topic/69247-looking-for-nylon-or-cloth-high-temperature-resistance-sheath/ Share on other sites More sharing options...
February 12Feb 12 comment_674487 I've used the braided split loom in my engine bay. No problems with heat, but it does collect dirt and grime over time and can't simply be wiped off - much like the corrugated plastic you have now. It looks a lot better though... Link to comment https://www.classiczcars.com/forums/topic/69247-looking-for-nylon-or-cloth-high-temperature-resistance-sheath/#findComment-674487 Share on other sites More sharing options...
February 13Feb 13 Author comment_674491 Ive seen several on Amazon: https://www.amazon.com/gp/product/B0D5GZQYXP/ref=ox_sc_act_title_2?smid=A1DGO48EAHVET1&th=1 https://www.amazon.com/gp/product/B0C4LDSBF4/ref=ox_sc_act_title_3?smid=A1D2WOR1KGBRUG&th=1 Which one one would you recommend? Link to comment https://www.classiczcars.com/forums/topic/69247-looking-for-nylon-or-cloth-high-temperature-resistance-sheath/#findComment-674491 Share on other sites More sharing options...
February 13Feb 13 comment_674493 The only real difference is the weave. Some is tight and thick, some is a much looser weave and it's really just personal choice. I've used both but I prefer the tighter weave - more opaque looks more substantial but it is no easier to keep clean. Keep in mind that I daily drive my car in Phoenix Arizona so the dust and grime probably accumulates a bit quicker for me than many other Z drivers. Years ago when I first looked for sheath it was "Tech Flex (F6 or something like that)" - no idea if that's still available. Now I'm building a new engine harness for my L28ET and I'm using RayChem. Link to comment https://www.classiczcars.com/forums/topic/69247-looking-for-nylon-or-cloth-high-temperature-resistance-sheath/#findComment-674493 Share on other sites More sharing options...
February 14Feb 14 Author comment_674495 On 2/13/2025 at 6:25 PM, cgsheen1 said: The only real difference is the weave. Some is tight and thick, some is a much looser weave and it's really just personal choice. I've used both but I prefer the tighter weave - more opaque looks more substantial but it is no easier to keep clean. Keep in mind that I daily drive my car in Phoenix Arizona so the dust and grime probably accumulates a bit quicker for me than many other Z drivers. Years ago when I first looked for sheath it was "Tech Flex (F6 or something like that)" - no idea if that's still available. Now I'm building a new engine harness for my L28ET and I'm using RayChem. So 1/4 or 1/2 inch diameter? I guess 1/4 is the way to go Link to comment https://www.classiczcars.com/forums/topic/69247-looking-for-nylon-or-cloth-high-temperature-resistance-sheath/#findComment-674495 Share on other sites More sharing options...
February 14Feb 14 comment_674532 I've used 1/8" - 3/4". Mostly 3/8". Whatever you need to fit the wire bundle you're sheathing. I like to keep it tight as possible. Link to comment https://www.classiczcars.com/forums/topic/69247-looking-for-nylon-or-cloth-high-temperature-resistance-sheath/#findComment-674532 Share on other sites More sharing options...
