March 1Mar 1 comment_675011 The testers normally seal just like the radiator cap which seals the port to the overflow tank Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675011 Share on other sites More sharing options...
March 2Mar 2 Author comment_675024 10 hours ago, Patcon said: The testers normally seal just like the radiator cap which seals the port to the overflow tank I am not able to seal the water **** with this o-ring. Water droplets ozz out after 2-3 mins of idling. I am not sure what to do here. This vacuum co*k is a nightmare. I am thinking to use GE Silicon around it 😆 - but I want to try the guy recommended in the old thread in WI who fixes it. May be he has a cure. Planning to send it to him. He charges $100. Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675024 Share on other sites More sharing options...
March 2Mar 2 comment_675025 Sounds like a good idea to me. Fortunate you were able to find some one that’s willing to take it on Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675025 Share on other sites More sharing options...
March 2Mar 2 Author comment_675027 33 minutes ago, Yarb said: Sounds like a good idea to me. Fortunate you were able to find some one that’s willing to take it on He has mentioned o-ring wont work and that correct flat washer will and he will pressure test it as well before shipping. Keeping my fingers crossed. Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675027 Share on other sites More sharing options...
March 12Mar 12 Author comment_675273 Joe heatervalves.net was a life saver. Shipped the valve back within 24-hours of getting the new seal in and water pressure tested. Ran the car idle 10 mins and all seems nice and holding.U hose was: Dayco 86050 the exact fit with some trimming. Edited March 12Mar 12 by MH77280Z Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675273 Share on other sites More sharing options...
March 12Mar 12 Author comment_675274 While we are on this topic, where do u get this black insulation that is on the vapor line coming from evaporator in the dash and going into engine through the firewall?there is a rip in it and I was wondering to redo this before I put the dash back. Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675274 Share on other sites More sharing options...
Thursday at 04:55 PM5 days comment_675284 On 2/27/2025 at 3:41 PM, MH77280Z said:I would change that lower braided hose for something newer if it were mine. Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675284 Share on other sites More sharing options...
Thursday at 05:17 PM5 days Author comment_675285 20 minutes ago, siteunseen said:I would change that lower braided hose for something newer if it were mine.I thought about it, it looks a bit beat up but was actually in a better shape than the other two U and elbow which I did changed.Is there a matching replacement for it? Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675285 Share on other sites More sharing options...
Thursday at 06:01 PM5 days comment_675286 I would just use heater hose from a chain parts store. Isn't that what you have on the others?That braided stuff is original to the car so the rubber you can't see is most likely getting brittle. Just a guess but "why you're there". 😁 Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675286 Share on other sites More sharing options...
Monday at 12:12 AM1 day Author comment_675329 On 3/13/2025 at 11:01 AM, siteunseen said:I would just use heater hose from a chain parts store. Isn't that what you have on the others?That braided stuff is original to the car so the rubber you can't see is most likely getting brittle. Just a guess but "why you're there". 😁Ok so here it is Gates 19044. It’s a longer hose that can be cut to the right fit but is a 99% match. I can throw my old ones safely 😊 Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675329 Share on other sites More sharing options...
Monday at 12:44 AM1 day comment_675330 Good find. I’ve found if you have a good relationship with a parts store. I have had great luck walking in with the original, find something on there hose rack that has similar bends and adjust as needed. Link to comment https://www.classiczcars.com/forums/topic/69254-280z-water-removal-sequence/?&page=4#findComment-675330 Share on other sites More sharing options...
