Posted February 24Feb 24 Popular Post comment_674884 This post was recognized by bpilati! zKars was awarded the badge 'Great Content' and 15 points. "Helpful DIY post." Some of you have dealt with this little annoyance, and I have found a perfect solution. When doing a full restoration, or at least the full interior, you often have to replace the head liner and the A pillar vinyl, as well as the vinyl trim that goes across the top of the windshield where the sun visors and rear view mirror mount. While I wonât discuss the pain of installing these items, what I have found is even more of a pain, is finding the nine M5 threaded holes to put the visor and mirror mount back in. All that fresh painfully installed lovely vinyl, and 9 secret  little holes you have to find to poke holes through. Get out the pokey thingy of your choice and start poking until you find them.  If you put some kind of thin foam behind the vinyl like youâre supposed to, those damn holes are just a nightmare to sleuth out. Not any more! I put some nice long M5 grub screws in the nine threaded holes, THEN do the upholstery.  Then finding the tips of them sticking out is easy! Make little âXâ slits to expose them, grab your M3 hex key, back them out and screw in the visor and mirror mounts. Five minutes each! Easy peasy. Edited February 26Feb 26 by zKars Link to comment https://www.classiczcars.com/forums/topic/69256-little-shop-trick-to-share-installing-sun-visors-and-interior-mirror/ Share on other sites More sharing options...
February 25Feb 25 comment_674887 Now you tell me! Link to comment https://www.classiczcars.com/forums/topic/69256-little-shop-trick-to-share-installing-sun-visors-and-interior-mirror/#findComment-674887 Share on other sites More sharing options...
March 3Mar 3 comment_675077 You could also make a template. Link to comment https://www.classiczcars.com/forums/topic/69256-little-shop-trick-to-share-installing-sun-visors-and-interior-mirror/#findComment-675077 Share on other sites More sharing options...
March 19Mar 19 comment_675349 My painter did not think this part through and now i have to poke into my vinyl to find the screw holes. any advise for finding the holes without putting 1,000 holes in my new vinyl. Link to comment https://www.classiczcars.com/forums/topic/69256-little-shop-trick-to-share-installing-sun-visors-and-interior-mirror/#findComment-675349 Share on other sites More sharing options...
March 19Mar 19 comment_675350 You should be able to easily locate the larger hole at the center of the three hole pattern, to get close. It is a little bigger than 5/8" diameter. Hopefully even through the padded vinyl you can find that hole and then as @bpilati mentioned, use a template traced from the visor. Good Luck. đ Edited March 19Mar 19 by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/69256-little-shop-trick-to-share-installing-sun-visors-and-interior-mirror/#findComment-675350 Share on other sites More sharing options...
