Rear tie down hooks for originality: Yes or no? 8 members have voted
  1. 1. Did you or will you put them on your Z. This is only for those that are trying to go as original as possible.
    • Yes
      5
    • No
      3
    • I'm not sure yet as I haven't really thought about them.
      0
Please sign in or register to vote in this poll.
I've just started thinking about these as I near closer to completion of my old z.  They weren't on when i bought the car in'93, but as I pour over pictures of original early z's, it appears they all still have them in place.
Follow up question:  Are the rear hooks the same dimensions as the front passenger one?
3 hours ago, zKars said:
The memory is swirling with details of tow hooks, but I would like to point out that from the point of view of originality, the presence of tow hooks is optional.
First remember they are tie down hooks, not tow hooks. They secured the car to the boat they came over on.
Memory of past discussions suggests there was a Nissan order to dealers that they be removed before selling. Correct me if that’s wrong. Seems from the many Z’s I’ve seen, most still had “some” so I suspect many dealers didn’t bother.
So it would appear to be “Correct” to have them or not on a restoration. If you could somehow know if they were there or not on delivery day for your particular car, then you would know to either include them or not to make it “right”.
Then the issue of what particular style was installed at each of the four spots comes up, but I think that was covered in some other thread.
I made a coat hook rack for the back of my shop door out of some of the ones I have laying around. Probably sacrilege to some. Too bad.
How many timing chains around the Z? That is a great piece of artwork you've made there.
I want one!!!!
Exactly one chain. Printed out a side view and laid out the chain around the outline. Took a couple of zooms in and out to get the scale down to exactly one chain. Added a couple of embellishments.
Gotta do a 510 next. Can do another Z if you want!
Edited by zKars
