Posted February 28Feb 28 comment_674954 Guys two questions: 1. in pic#1 the S vacuum line connects to the control assembly inside the dash. There is some sort of a check valve in pic#3 mounted right under the magnetic valve where this line connects per pic#2. I assume it is the smaller end facing towards the firewall where this S line connects too? The other end bigger end will connect to magnetic end D and M via 3-way line. Is my understanding correct? Also, does it matter if the S1 and S2 lines on the vacuum tank are reversed? Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/ Share on other sites More sharing options...
February 28Feb 28 comment_674963 Per the diagram it looks like S1 goes to the engine side. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674963 Share on other sites More sharing options...
February 28Feb 28 Author comment_674964 2 hours ago, Yarb said: Per the diagram it looks like S1 goes to the engine side. Is there some kind of machanism inside this vacuum tank? i assume u mean vacuum tanl S1 and S2 cannot be reversed. I am trying to figure out the orientation of the tank to make sure S1 and S2 are at the right location. Per my pic, i assume my S2 is connected to S1 on the tank which is wrong correct? Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674964 Share on other sites More sharing options...
February 28Feb 28 comment_674965 Two separate ports per the diagram from what I see. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674965 Share on other sites More sharing options...
February 28Feb 28 comment_674966 They can be switched. There's no mechanism inside the tank. The check valve is important though. Be careful with the hoses, they are an odd size and tend to split because they're so old. I spent a lot of time fixing mine, as they kept splitting at the ends, then the check valve went bad. Overall, it was a pain keeping everything working right. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674966 Share on other sites More sharing options...
February 28Feb 28 comment_674975 When running, the intake manifold is a vacuum source but depending on the engine load the amount of vacuum can vary wildly. The check valve prevents the intake manifold (engine) from sucking the vacuum BACK OUT of the bottle when the engine load is high and/or the intake manifold vacuum is reduced. It's important that the vacuum bottle keeps enough vacuum to run all the vacuum solenoids. The check valve is a huge part of that. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674975 Share on other sites More sharing options...
February 28Feb 28 Author comment_674976 38 minutes ago, cgsheen1 said: When running, the intake manifold is a vacuum source but depending on the engine load the amount of vacuum can vary wildly. The check valve prevents the intake manifold (engine) from sucking the vacuum BACK OUT of the bottle when the engine load is high and/or the intake manifold vacuum is reduced. It's important that the vacuum bottle keeps enough vacuum to run all the vacuum solenoids. The check valve is a huge part of that. That’s what I was trying to confirm. The check valve pic I posted show the bigger side facing radiator. On the inside is the smaller end. Per FSM pic I assume the bigger end connect to the 3-way connector on the solenoid and smaller goes to S towards the dash through the firewall. Don’t want to connect this one reverse!!! Can someone confirm. Edited February 28Feb 28 by MH77280Z Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674976 Share on other sites More sharing options...
March 1Mar 1 comment_674977 Just try it and see. You are not going to damage anything. You have gotten good advice so far. Analyze what you have and give it a try. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674977 Share on other sites More sharing options...
March 1Mar 1 comment_674979 The check valve is designed to let air pass out of the bottle and in to the intake manifold, (darn it, I knew I'd do that), but not from the manifold to the bottle. The hose with the check valve is the one that loops around to the tiny nipple on the top of the manifold. Suck on the valve to determine which end points toward the manifold. Edited March 1Mar 1 by Zed Head still wish we had the option to cross out text. all of the other forums have it in the Edit screen. Edit is where it makes the most sense. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674979 Share on other sites More sharing options...
March 1Mar 1 Author comment_674980 I figured, i accidentally thought that grommet is the valve … so the manifold connects into smaller end - bigger goes to S1 in the vacuum tank. S2 from the tanks goes to the solenoids. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674980 Share on other sites More sharing options...
March 1Mar 1 comment_674981 My early '77 doesn't have that bottle, just the charcoal cannister. Anybody Anyone know what year they started using those bottles? @Zed Head the cross out text isn't the same as strikethrough? Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674981 Share on other sites More sharing options...
March 1Mar 1 comment_674982 Yes, it's strikethrough. Couldn't remember the name. It's here in the first box, but not the Edit box. Weird. I had one on my 76 but maybe it's an AC system only thing. I had AC. Link to comment https://www.classiczcars.com/forums/topic/69261-vacuum-s-line-280z/#findComment-674982 Share on other sites More sharing options...
