Posted July 8, 200321 yr comment_43145 The smog pump in my 72 has developed a deep tapping noise. Any ideas before I tear into it. Link to comment https://www.classiczcars.com/forums/topic/6929-smog-pump/ Share on other sites More sharing options...
July 8, 200321 yr comment_43150 Correct me if I'm wrong, but isn't your Z smog inspection exempt? If so, save yourself some $$$ and ditch the smog stuff!!! It will also improve your performance! That's just one mans opinion. Link to comment https://www.classiczcars.com/forums/topic/6929-smog-pump/#findComment-43150 Share on other sites More sharing options...
July 8, 200321 yr Author comment_43152 I would eliminate it but the car is all original with only 93,000 show quality and I want to keep it as original as possible. Link to comment https://www.classiczcars.com/forums/topic/6929-smog-pump/#findComment-43152 Share on other sites More sharing options...
July 8, 200321 yr comment_43154 You would probably be just as well off to go ahead and buy a rebuilt pump if you want to keep it original. MSA has them for about 110 bucks, (with a 50 dollar core charge), which would be much simpler than trying to find parts to rebuild the one you have as I don't know that you would be able to find them. I've never seen rebuild kits or parts for them advertised anywhere so you might have to do a lot of work to rebuild it yourself. It's either that or find a good used one. Link to comment https://www.classiczcars.com/forums/topic/6929-smog-pump/#findComment-43154 Share on other sites More sharing options...
