Hey guys;
I have got a 700R4 in my 72Z and I am wondering if anyone can tell me the approiate angles for the driveshaft. Right now the tailshaft of the trans is about a 1/2 inch to the drivers side of the input shaft of the rear diff and about an inch higher.
Thanks
Peter:devious:
https://www.classiczcars.com/forums/topic/6930-drive-shaft-angle/
Height difference of one inch should be no problem. The problem is the longitudinal difference, you need to have them lined up as near perfect as possible or you will end up with harmonic and static imbalances. You'll need to get the rear of the trans moved to line up with the rear diff one way or another.
