Posted Yesterday at 02:43 AM1 day comment_675828 Still in the crate. Has odd exhaust ports. Has anyone seen this before?Also has an odd "temperature sensor bung" that looks like it was welded on. Maybe for use in the 280ZX? N42 heads didn't use the cylinder head temperature sensor.Bring a TrailerNo Reserve: Datsun L28 Crate EngineBid for the chance to own a No Reserve: Datsun L28 Crate Engine at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #190,091. Link to comment https://www.classiczcars.com/forums/topic/69350-check-out-this-atk-crate-l28-engine-on-bat/ Share on other sites More sharing options...
8 hours ago8 hr comment_675842 Already $1800. I'm surprised it's that high considering it's been sitting and you really don't know what you've got until you take it apart.Is the compression ratio a turbo level compression ration? Link to comment https://www.classiczcars.com/forums/topic/69350-check-out-this-atk-crate-l28-engine-on-bat/#findComment-675842 Share on other sites More sharing options...
2 hours ago2 hr Author comment_675851 Somebody called datsunparts bid $2200. There's a business called datsunparts, looks Roadster focused. Might be worth more parted out. Those exhaust ports are weird. Maybe it's a "detuned" L28 for a different model. Maybe the Z's got the good stuff.https://datsunparts.com/ Link to comment https://www.classiczcars.com/forums/topic/69350-check-out-this-atk-crate-l28-engine-on-bat/#findComment-675851 Share on other sites More sharing options...
