Posted Sunday at 08:44 PM2 days comment_675865 A few months ago, I created a differential cover to go with the KAAZ LSD I installed last year. I finally got around to installing the cover and as fast as I filled it, the gear lube leaked out. I'll pull the cover and see if I can figure out what I did wrong but for now, I'm going back to the original cover for now. I'm guessing there is a problem with the mating surface. I'm not necessarily posting for advise as much as I need to vent. Hopefully my other little projects worked out better so I can get my Z back on the road. Other projects I'm finishing up include a freshly rebuilt 5-speed, oil pan gasket to stop the oil leaks (I hope), DIY engine splash shield, and fabricating plastic inner fender covers. Link to comment https://www.classiczcars.com/forums/topic/69351-diff-cover-looks-great-leaks-as-fast-as-i-fill-it-ill-try-again-this-fall/ Share on other sites More sharing options...
Sunday at 10:05 PM2 days comment_675867 Well that's no fun! Link to comment https://www.classiczcars.com/forums/topic/69351-diff-cover-looks-great-leaks-as-fast-as-i-fill-it-ill-try-again-this-fall/#findComment-675867 Share on other sites More sharing options...
