9 hours ago9 hr comment_675911 I'd start with a new battery and retest. I suspect the alternator or voltage regulator is bad, too. It may be as simple as overworking the alt. while trying to charge a battery that won't take a charge. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675911 Share on other sites More sharing options...
9 hours ago9 hr comment_675912 4 hours ago, Zedyone_kenobi said:I pulled the alternator this morning (wearing my osha white safety socks - those who have followed my Z build will understand) and plan on taking it to get tested this afternoon. None of my connections were lose or corroded. No matter what I do the amperage never changes or moves with revs and the battery will NOT read more than 12.3 volts.The problem is that I don't see the results of the tests I suggested you do. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675912 Share on other sites More sharing options...
8 hours ago8 hr comment_675913 On 4/28/2025 at 10:48 AM, SteveJ said:Since the car is modified, the field wire is jumpered to the ignition wire, and the neutral wire is jumpered to the battery wire.So this is not the factory setup for a 71? Does it have Dave Irwin's internal regulator modification? Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675913 Share on other sites More sharing options...
6 hours ago6 hr Author comment_675916 I am currently running the MSA 60 amp alternator kit. It was purchased back in 2010. All my tests were at the battery. After I get the alternator tested, I will run the tests SteveJ mentioned. If the alternator comes back bad, then issue solved. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675916 Share on other sites More sharing options...
6 hours ago6 hr comment_675917 2 hours ago, Zed Head said:So this is not the factory setup for a 71? Does it have Dave Irwin's internal regulator modification?I have seen the diode fail open in that design before. That would keep the car from charging. Also, if the ignition fuse in the fuse box is blown, it won't charge. The test I asked @Zedyone_kenobi to perform would help to identify those problems. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675917 Share on other sites More sharing options...
5 hours ago5 hr Author comment_675918 Worry not my good man, your words of advice will not go unheeded. I will check out those parts this evening when I get home. A simple Alternator test is just one more part of the equation. It is simple and free. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675918 Share on other sites More sharing options...
4 hours ago4 hr comment_675920 8 hours ago, Zedyone_kenobi said:I pulled the alternator this morning (wearing my osha white safety socks - those who have followed my Z build will understand) and plan on taking it to get tested this afternoon. None of my connections were lose or corroded. No matter what I do the amperage never changes or moves with revs and the battery will NOT read more than 12.3 volts.Zedy…..Glad to see you still wearing your steel toed safety socks!!!! Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675920 Share on other sites More sharing options...
3 hours ago3 hr Author comment_675922 Okay updateAll fuses are okay.One of the female spades in the "T" connector has 12.7 volts with the key off. The key in the Run position reads 11.8V but that also powering a electric fuel pump, so that is fine Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675922 Share on other sites More sharing options...
3 hours ago3 hr comment_675924 The alternator test at the parts store? Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675924 Share on other sites More sharing options...
2 hours ago2 hr Author comment_675928 The alternator tested a big green check at the parts store. However, I tried to test to find any out put from the T connector while the alternator was running well I got nothing, but it would see that it fried my volt meter LOL LOL. I am sure I should have measured the red/white wire from the back of the alternator instead. But now I have to get a fuse for my voltmeter or a brand new voltmeter... which would not be horrible. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675928 Share on other sites More sharing options...
2 hours ago2 hr Author comment_675929 Now I have no idea what the test read, as it only comes back with a big green check. No voltage out put was displayed. According to the 72 Z wiring diagram the red/white wire runs back to the fusebox, so that seems like it should be supplying the car with power after the car starts. My problem is that the wiring diagram shows the voltage regulator and I am running an internally regulated alternator. So I have to figure our which wire it is that should be charging my battery and which is supplying the car with power (me thinks red'white) Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=2#findComment-675929 Share on other sites More sharing options...
