Posted 11 hours ago11 hr comment_675910 Hi all - I took the spring-loaded seat hinge apart to re-grease it since it was making a squeak noise when I moved in the seat (the arm that sits between the seat back and bottom that does not contain the angle adjusting hinge) and after re-assembling it, the hinge flops around.Does the spring need to be spun to get tensioned before re-assembly? If so, how is that done? Link to comment https://www.classiczcars.com/forums/topic/69355-seat-return-spring/ Share on other sites More sharing options...
4 hours ago4 hr comment_675923 By chance did you try a cleaner and spray able grease before you removed it. Trying to understand the process you went with. Link to comment https://www.classiczcars.com/forums/topic/69355-seat-return-spring/#findComment-675923 Share on other sites More sharing options...
4 hours ago4 hr Author comment_675926 26 minutes ago, Yarb said:By chance did you try a cleaner and spray able grease before you removed it. Trying to understand the process you went with.I did but to no avail. I even ended up blasting the old grease/dirt out with brake cleaner and then relubing it with sprayable silicone lubricant but the squeak didn't go away Link to comment https://www.classiczcars.com/forums/topic/69355-seat-return-spring/#findComment-675926 Share on other sites More sharing options...
