Steel Dashboard Frames Required
Originally posted by SoCalZ
Jim, What is the going rate for the frames?
:classic:
Hi,
We buy most RHD dash frames from wrecking yards for A$30 - A$50 each, however, LHD are difficult to locate here in OZ so it is a matter of how much a seller want's v's how much we are prepared to pay. Jim
I have a dash from a early '70 240 it has two hairline cracks on the top from the dash across and down to area next to the tack and another the same that is next to the clock . In the recess in front of the amp meter there is a hole with some of the foam missing , it is about the size of a neckel.
Jim,
If it helps, it's my understanding that the early Series I dash is all but identical to the Series II dash. The only difference being the cut-out for the cigarette lighter. Which, on the Series I dash, the indentation is already there. FWIW...
