Al Squillante Posted July 19, 2003 Share #1 Posted July 19, 2003 I have my L24 rebuilt head in hand and am ready to install it. I cant seem to loosen the bolt holding the sprocket. Is this a left hand thread? I would like to get the sprocket off before I install the head.Al. Link to comment Share on other sites More sharing options...
santamaus Posted July 19, 2003 Share #2 Posted July 19, 2003 I can't say I recall which way I spun it to loosen, but I'm pretty sure it's threaded the normal way. The trick is finding some way to lock the sprocket in place so you can put enough force through that bolt to loosen it up. I *do* remember working up a pretty solid sweat getting it off.Good luck!Chris Link to comment Share on other sites More sharing options...
JEFF Posted July 20, 2003 Share #3 Posted July 20, 2003 That sprocket bolt is a right hand thread. Try "shocking" it loose with a quick smack on the 19mm wrench using a steel hammer or a dead blow hammer. That is the best way if you don't have a air impact wrench.- Jeff Link to comment Share on other sites More sharing options...
Ben Posted July 21, 2003 Share #4 Posted July 21, 2003 There are bosses in the middle of the cam that you can lock onto with a pair of vise-grips. Then make sure that you have a soft surface (block of wood) for them to jam against (not the head).The last step is to apply liberal torque to a 19mm socket drive:classic: Link to comment Share on other sites More sharing options...
Al Squillante Posted July 21, 2003 Author Share #5 Posted July 21, 2003 I want to thank Santamaus, Jeff and BenI finally was able to get the bolt holding the sprocket on loose. A long bar and a lot of hits with a hammer while holding the shaft with a vise grip. No damage . I finally got the head bolted on and installed the spocket to the chain after I torqued the head down. Much to my suprise the sprocket slid right on . The wood chock I used held the chain in place . Link to comment Share on other sites More sharing options...
