  • 3 weeks later...
I can recommend the MSA rear bar for the early car. It fit well on my 72. I did require the use of a lift to install it. I also changed the supplied hardware with beefier stuff. It's a bit of a hassle, but it's worth it. To install it you have to replicate the mounting points of the later cars. So, youv'e got to drill the floor. The bolts supplied were not long enough with out washers and I wanted BIG THICK washers to spread the load. I also bought "Nylock" nuts to get it all tight over the years.
By the Way, as I recall, It looked very much like the one in your photo.
there are 2 types of sway bars for the rear of hte z:
the msa bar mounts to the body behind the rear seats. holes need to be drilled
the other type (forget the make) sits 180* rotated, and mounts to the rear crossmember behind the diff. The one that supports the rear A arm bushings.
Some Z's came without the bracket for a rear sway bar.I found this out when I got a msa/front/rear sway kit.Thanks victor for the photo so I can see what I need to do.Texasz I thought of putting the front only on until I got the rear info I needed.I was told that they are made to work inpairs.So even if it fit your car it may cause poor results with the front unit.I'm sure someone will put more lite on this.
