M3 mirrors
drunkenmaster
They dont look too bad, but just a couple of comments
How well does the angle on that mirror match the angle on the stainless door frame? Are you going to end up with a big gap, or a mirror that looks likes its skewiff? As to mounting them on the frames, its a whole heap harder to cover holes in a stainless steel frame than it is in a door sking should you change your mind at a later date. Be nice to see a set just double side taped on your car to see what they look like?
As for not wanting door mounted mirrors, I am with you 100 percent on that comment, But I will end up going more traditional with my mirrors.
If that front angle could be made to match well, they should be a very neat looking install, if not it could look a bit tacky.
Good Luck
Cheers Chris
