Posted July 23, 200321 yr comment_44881 How do u shorten strut housings and what kind of inserts do u use after u shorten them? Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/ Share on other sites More sharing options...
July 23, 200321 yr comment_44930 Use a large pipe cutter and remove the desired amount from the housing about one inch down from the threads at the top. Carefully weld the pieces back together so the housing is perfectly straight. Use Tokiko or Koni inserts. I'm sure others will work also. To determine the amount to remove, take the new insert and place into the housing. Place a piece of masking tape on the insert rod at the housing cap. Lift the insert until it hits the housing cap and place another piece of tape on the rod. Measure the distance between the two peices of tape. Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/#findComment-44930 Share on other sites More sharing options...
July 23, 200321 yr Author comment_44972 do i get inserts that are made for 280's or do i get them according to the length i remove? Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/#findComment-44972 Share on other sites More sharing options...
July 24, 200321 yr comment_44984 You need to get the inserts first. Some of the inserts such as Konis are a real tight fit so you have to be VERY careful of making sure things are straight when you weld the housing back together.For Koni inserts or more detailed information, contact True Choice or Ground Control.Each brand of insert may have a slightly different length. Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/#findComment-44984 Share on other sites More sharing options...
July 25, 200321 yr Author comment_45139 so do i get ones for the 280z or get ones made for another car with a shorter length and same diameter? Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/#findComment-45139 Share on other sites More sharing options...
July 25, 200321 yr comment_45156 You would be best to contact the folks at the two places I mentioned to find out about what to really get. Because of the dimensions, I think you will need struts made specifically for the Z. I think they are interchangeable between the 240/260/280. If you are looking at doing autoX or simply just street driving you would probably be okay with Tokikos -- they are less expensive than Konis but don't last as long. Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/#findComment-45156 Share on other sites More sharing options...
July 26, 200321 yr Author comment_45205 Thanks! Link to comment https://www.classiczcars.com/forums/topic/7150-shortening-strut-housings/#findComment-45205 Share on other sites More sharing options...
