Posted January 16, 200223 yr comment_2000 Both sides, in good condition of course - especially seat bottoms, as I have already rescued two good condition black vinyl seat backs from the junkyard.If I can find these OEM seats then I will have two old Recaros to give away to whomever wants... they are black velour, have adjustable thigh support on driver side, look like the old LX models if you remember that far back, and yes the black velour fabric is torn in places but the foam is intact... Comfortable enough - just not the OEM look that I am after.Thanks.-e Link to comment https://www.classiczcars.com/forums/topic/720-i-need-black-oem-vinyl-240z-seats-please/ Share on other sites More sharing options...
January 16, 200223 yr comment_2004 What year?Or what style I should say.The early had round knobs for moving the seatback(incline).Later had a lever. Link to comment https://www.classiczcars.com/forums/topic/720-i-need-black-oem-vinyl-240z-seats-please/#findComment-2004 Share on other sites More sharing options...
January 16, 200223 yr Author comment_2008 That isn't so important to me... The two backs I salvaged from the yard were the later kind with the lever as you've described it. Do you have either?-e Link to comment https://www.classiczcars.com/forums/topic/720-i-need-black-oem-vinyl-240z-seats-please/#findComment-2008 Share on other sites More sharing options...
January 16, 200223 yr comment_2009 Just my 2¢ worth.I think that you will find that between buying the seat backs, and the shipping involved you might be spending more money than just having them recovered.Your not being particular as to whether the seats were lever or knob actuated tells me you may not be going for a concours restoration, but I may be wrong. If you aren't, then by getting the ones you have recovered as well as the seat bottoms, you may be money ahead. Link to comment https://www.classiczcars.com/forums/topic/720-i-need-black-oem-vinyl-240z-seats-please/#findComment-2009 Share on other sites More sharing options...
January 17, 200223 yr comment_2027 I have a friend that did have some 70 seats .I'll check with him.I had my seats redone some years ago.The matching vinyl was easy to find.The problem was the 4 chrome breather vents in each seat.I found brass ones are used in the furniture business as vent for vinyl cushions.I had 10 chromed seat man messed up 1 used 8. Daniel Link to comment https://www.classiczcars.com/forums/topic/720-i-need-black-oem-vinyl-240z-seats-please/#findComment-2027 Share on other sites More sharing options...
