I pulled a 280zx distributor at a junkyard to throw on my L24. I've been searching the threads here and on Zcar.com and the posts said to use the ZX coil with the conversion. Since I first heard of this on the Z garage website and never saw this mentioned, I purchased the Crane cams PS20 coil from MSA. Will this work?
https://www.classiczcars.com/forums/topic/7374-coil-for-zx-dist-conversion/
  • 7 months later...
Any low resistance 12V coil should work fine, one that is for electronic ignition. You just can't use a coil like the original 240 points coil, which is 6V and a high resistance primary coil.
Don't forget, when you get your new coil, bridge (remove) the ballast resistor. If your old coil had a double spade connector on one of it's posts, steal that to connect the two sides of the ballast terminals, then tape it up.
Thanks.I measured about 1.7 Ohms on the primary side of the coil.Is this a disadvantage?I would think it would limit my secondary voltage.It's a Crane PS20,should I upgrade or stick with this one?
It's been a while but I think the old style coils were like 30-300 ohms while new style are 10 or less. Most of the new ones I've seen have "for use with electronic ignitions only" printed on the side. These are the low impeadance ones.
