Posted August 9, 200321 yr comment_46598 on my 260z turbo engine (Janspeed with S.U 2"), i find champion n9yc spark plugs when i bought it, when i contact Janspeed someone tell me to used NgK BPR 7 ES, Someone knows spark plugs sufficiently to tell me if there is a big difference between this to types and which is the best for my engine? Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/ Share on other sites More sharing options...
August 9, 200321 yr comment_46623 I was using Champions but the car never seemed to burn right. I mainly use the car for track work so revs are always high.Moved over to NGK and quite happy with themNo1 son races motorcycles and he does not use anything but the NGK plug. Swears by them:love: Biker Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46623 Share on other sites More sharing options...
August 10, 200321 yr comment_46635 When I bought my 240 3 yrs ago it had champions in it and it ran like crap. They were almost new too. Pulled them installed NGK6 and have never looked back the engine runs great. :classic: Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46635 Share on other sites More sharing options...
August 10, 200321 yr comment_46637 I just recently replaced mine.. and I have always used NGK plugs for my Nissan Sentra, my dad's Suzuki motorcycle....and originally on my Z.. but I went to Napa, Checkers, and Auto Zone, and non of them carry NGK's for my Z, but they carry NGK sparks? Through all the frustration, I bought some Bosch platinum plugs... they say if I am not happy with them i can get my money back Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46637 Share on other sites More sharing options...
August 10, 200321 yr comment_46640 all my old Bosch's with NGKs and my Z runs like new! It's a HUGE Difference! Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46640 Share on other sites More sharing options...
August 10, 200321 yr comment_46642 Bosch and NGK all the way.NGK plugs and leads, Bosch Coil runs magnificent.The most important thing is to make sure the spark plug gap is right if there not already gapped for a Z. Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46642 Share on other sites More sharing options...
August 10, 200321 yr comment_46666 I don't care what they told you, NAPA CARRIES NGK! NGK BP6ES is NAPA Part # NGK7333 @ $1.89Also availible onlline at Napa Auto Parts Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46666 Share on other sites More sharing options...
August 10, 200321 yr Author comment_46673 thanks guysNGK BP6ES is the original type recommand by Nissan for a stock Engine and if mine was stock i will used this model....But as mine engine as a turbo kit it will probably run at higher temperature, so i can used the same type.the number in the sparks model is the heat level the most higher is the number the most the spark was hot sparks.But i don't know the signification of BP and ESthe Janspeed recommand are 7 so most higher temperature here was the probleme and i don't know the difference between BP ES and BPR ESSo the champion N9YC are probably too hotSomeone know all this signification? Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46673 Share on other sites More sharing options...
August 10, 200321 yr comment_46675 If they suggest the cooler BP®7ES, go for it. The "P" means "Projected tip" The "R" means "Resistor"The R doesnt change much, same plug, but with a resistor for noise suppesion. I never use them, just supersitious I guess.So the champion N9YC are probably too hot Don't know. Different Manufacures use different numbering systems. With NGK's the higher numbers are cooler. A hotter plug than BP®6ES would be BP®5ES NGK FAQ Page Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46675 Share on other sites More sharing options...
August 10, 200321 yr Author comment_46679 thanks for this interesant link.If the different manufacures didn't speak the same language it will be difficult to compare, but so i understand why janspeed recommand this type of plugsThanks Benoît Link to comment https://www.classiczcars.com/forums/topic/7426-spark-plugs/#findComment-46679 Share on other sites More sharing options...
