Posted August 11, 200321 yr comment_46780 i have a 71 240 and i have a 5 speed that i want to put in. do i have to remove the exhaust to get it out? can i squeese it by? i have a leak in my header that i dont want to fix because i am changing motors in the winter. if i have to take it off i will have to get a whole new system that i wont need in a few months. am i stuck with the 4 spd until then? Link to comment https://www.classiczcars.com/forums/topic/7456-trans-change-need-to-remove-eshaust/ Share on other sites More sharing options...
August 11, 200321 yr comment_46781 I have had a few exhaust systems that I have had to pull the exhaust, and some that I could just leave alone. It is jsut how the header is made and how the pipes are laid out. Good luck!!! Link to comment https://www.classiczcars.com/forums/topic/7456-trans-change-need-to-remove-eshaust/#findComment-46781 Share on other sites More sharing options...
August 11, 200321 yr Author comment_46782 thanks a lot well i dont know so i guess i will have to wait Link to comment https://www.classiczcars.com/forums/topic/7456-trans-change-need-to-remove-eshaust/#findComment-46782 Share on other sites More sharing options...
