Braking issue...Help!!
justaZcarguy
The haynes drawing shows two rods inside the booster that push the mstr to move.I would be interested in knowing with the mstr cyl removed or out of the way,how much push you were getting,how much travel the pedal made before the mstr cyl pushrod moved..Perhaps put a board in front of it and have someone push the brake pedal to see if you can hold it back.Also there is an adjustment on the pedal.Maybe it just needs a little more lenght forthe new mstr cyl.I now think I had to adjust mine.Good luck ,let me know.Oh check the distance the pushrod is from the push cup in the mstr.There are a couple of flavors out there and some are more recessed than others.
