updated 1/24/02 I have two left of these in good condition standard /standard. $350 per plus exact ups freight. Also have one that needs machine work done on front threaded pully hole. one common weakness of these cranks is stripped pully bolt holes. $250 on that one. These are hard to find, if you want to build that 3.1 stroker or stroke your tubo this is the ticket.:new email seven@mokancomm.net
https://www.classiczcars.com/forums/topic/753-ld-28-diesel-cranks/
Need to know where in Kansas you are located? I may be able to get one of those cranks from you. I will be coming thru that area next month and may be able to pick it up in person. I have to go to North Carolina to give my youngest daughter away on the 23rd of Feb 02. Also need a phone number where I can reach you? I am located in Colorado and may pick it up coming or going there. My e-mail address is Richard.Jerabek@State.CO.US . my phone number is (970) 330-8656.:D
