Posted January 20, 200223 yr comment_2187 up dated 1-24-02 TOO MANY PROJECTS/NEED SPACE COMPLET DIESEL LD 28 MOTOR SITTING IN MY HEATED SHOP FOR 6YEARS? AND IT NEEDS TO GO. these motors are the same block height as L20b. An engine builder in Georgia uses these blocks to build long rod strokers. Head bolts are twice the size of the gas block,trick is drilling out the aluminum head for them without hitting a water jacket ! Anyway alot of good parts here, oilpan are large capacity and bottom can be welded on a gas block pan for a cheap full race pan.oil filters housings are water cooled, and of course you are getting the strocker crank. $375 you pick up ,kansas city i set it in your truck.pictures ready ,email for them seven@mokancomm.net Link to comment https://www.classiczcars.com/forums/topic/754-ld-28-diesel-motor-comlete-82/ Share on other sites More sharing options...
January 21, 200223 yr comment_2203 FD, just post a pict in this forum. You'll get more hits. Link to comment https://www.classiczcars.com/forums/topic/754-ld-28-diesel-motor-comlete-82/#findComment-2203 Share on other sites More sharing options...
