I'm running the Isky L-480 on a bored out L24, E31 head w/ larger valves installed. Its a nice cam. Has a lope at idle. Isky has been in business for a long time and they also make the Nissan L7 and L9 race cams which are the Isky L-475 and L-490
I paid $180 and thats for the internally oiled camshaft. Crane Cams have gone up in price, $322 ouch!
You can call Isky and ask them about there cams. There is one guy I talked to who is very knowledgeable on Z's, sorry I don't remeber his name.
Mike
https://www.classiczcars.com/forums/topic/7566-isky-cams/#findComment-47418
I don't think the L-490 would be too much for that setup. When I talked to Isky they actually recommended the L-490. I went with the L-480 because I didn't want to get too much cam. Be sure your compression is around 10:1. You will also need to use performance springs since the lift will be well over .460
Mike
https://www.classiczcars.com/forums/topic/7566-isky-cams/#findComment-47465
I have used Isky for 40+ yrs and I think the co. and there cams are 1st rate. A friend of mine built a 4 engine dragster and used Iskys. Two engins ran clockwise and tow counter clockwise. That was light yrs ago but if a co is still in business you know they know what they are doing. Crane has been around a long time also , I would check them both out , and get the grind that sutes you best!
https://www.classiczcars.com/forums/topic/7566-isky-cams/#findComment-47511
