Due to the fact that both settings are screwy... I think you have a switch problem. Have you tried taking it apart and cleaning out the contacts?
If so, you might need to use a voltage meter to isolate the problem to the switch. And, if it's failing... replace it.
-- Mike
Mike Gholson
1971 240z, Mikuni Carbs, Tokico 5-way Adjustable Struts, Ferarri Yellow, Stock Engine, 15x9 wheels w/50 series Falken tires, Currently being restored.
