Hi all
Just started rebuilding the original engine from my 240z. I'm trying to get some assistance re removing the front pulley. I ve managed to get the large bolt undone by blocking the crank with a piece of wood inside the crank case and using a 2 foot extension on my socket handle, but I'm not sure how to get the pulley off. The haynes manual says something about not using a normal 2/3 leg puller on the pulley and shows a picture of some special tool that bolts up to 2 bolt holes on the front face of the pulley.
Any assistance gratefully received
AndrewB
240z LHD in UK
https://www.classiczcars.com/forums/topic/7601-front-pulley-removal-240z/
True, DO NOT USE the leg puller:finger: :finger: The lower pulley is also your balancer. If you use the leg puller you chance damage.:cry:
The tool you are talking about is cheap and worth it vs over 100 for a new lower pulley. It bolts into the center of the pulley. This will insure that it pulls the WHOLE pully off and not just the pulleys off the balancer :sleepy:
Lance
I don't suppose you know what the thread of the bolts you bought were? I know they are 10mm but they are not the same thread as the other 10mm bolts on the car
Err!!! I've just realised I posted in the 'for sale section' Doh!!
I have been a z owner since 1988 and I second your thoughts about wishing I'd been driving it all that time. I think I've managed about 3 years out of the last 15!!!!
regards
Andrew
No sorry I don't, it was about 20 years ago when I did it. I do remember picking them up at the local parts place, at the time I was one of the few in the area that ever wanted any metric fasteners :)
