Posted August 30, 200321 yr comment_48087 Can you see it? i was shocked to see this when i checked the plugs on my car i have just gotten it from another person not running cause the exsuast manifold was toast and he was switching out the flattops for some round but i coudent seem to tune the carbs in so i checked the plugs and low and behold this it what i saw...... number 6 didnt have a gap at all...... and whats with the differnt types?. yes i did replace them after this but i just thought id share Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/ Share on other sites More sharing options...
August 30, 200321 yr comment_48107 why are 1 and 6 longer than anythign else? Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48107 Share on other sites More sharing options...
August 30, 200321 yr comment_48111 but i did notice that 2-5 are the wrong plug. 1 and six seem to be the right plug.you did get yourself some NKG BPR6ES plugs right!ngk is the only way to go in these vehicles Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48111 Share on other sites More sharing options...
August 30, 200321 yr Author comment_48122 no i got the cheap autolights for now on a tight buget and need to see if the car is going to run decent or not i have to pull the radiator cause it leaks then find a colortune..... Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48122 Share on other sites More sharing options...
September 1, 200321 yr comment_48252 The middle 4 look like they came out of my lawnmower..... Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48252 Share on other sites More sharing options...
September 1, 200321 yr comment_48254 WICKED, you have a 4 cylinder lawnmower?! Just kidding. but seeing as it's plugs and while I'm here, does anyone run the BPR6EY, BPR6EIX or BPR6EGP ? instead of the BPR6ES? if so, any better or different? Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48254 Share on other sites More sharing options...
September 2, 200321 yr comment_48320 Originally posted by Xargon321 no i got the cheap autolights for now on a tight buget and need to see if the car is going to run decent or not i have to pull the radiator cause it leaks then find a colortune..... The NGK's are cheap anyway how much money could you save on cheaper ones?Just curious really?:classic: Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48320 Share on other sites More sharing options...
September 5, 200321 yr comment_48644 I only payed $ 10.00 for 6 NGKs how much did you save ? false savings me thinks , sports fansROFL Link to comment https://www.classiczcars.com/forums/topic/7681-whats-wrong-with-this-picture/#findComment-48644 Share on other sites More sharing options...
