Originally posted by bigd652
How do you get the steerig wheel off? Never done this before. Thanks
Pull off the horn pad. There's a nut in the middle that holds the steering wheel on - I believe it's 23mm; I'm not sure of the size because I just use a univeral lug wrench that happens to fit. After removing the nut and locking washer you should be able to pull the streering wheel off.
