We Need Your Help! ×
Toyota 4 piston caliper brake upgrade
ZmeFly
Originally posted by ZmeFly
this is for use with the stock rotor, complete remanufactured sets of calipers, brakes and pin and spring kit are included.
When where these remanufactured? How much use have they had since then? Sounds like all that's missing are the pads to start using them. Is this correct?
for the price i quoted these are ready to bolt on, all you have to do is bleed the brakes
what im selling comes with everything you need! all you do is the work to put them on:ermm:
the calipers are not used but new remanufactured units.
all you have to do is bolt them to your car, bleed them out and voila you are done.
It's OK to remove it, but, the worst part is you'll have to pull the hub to do it... Probably easier to just get a good set of tin snips and trim it a little to fit the caliper.....or a Dremel tool and then just file it (or sand it with the Dremel) off where you cut it just so you don't snag your hand on it later....:ermm:
