Posted September 3, 200321 yr comment_48477 I just picked up another 1972 240z yesterday after realizing the one I had needs alot of mechnical work like suspension and other saftey issue. I plan on swaping the good parts off one and putting it on the one I keep. Which one do you guys think I should keep1972 Yellow 4 speed Body is really nice and straight very light rust issues no major dentsCar has a newely rebuilt L24 engine and runs awesome Tranny is a little notchy but still works wellBrakes pull to one side when stopingSuspension is shot and bottoms out all the timeRegisteried in my name already and have the pink slipGlass is perfect all the way aroundFront carpet is decent No smog equipment attached New raditator No key's to anything including the ignition which I start with any keyHeater core removedDash has alot of cracks Center console is trashed Side Windows need realiningSome aftermarket wiring on some stuff like the lightsVent/ Fan controls don't really worktaillights have several cracks in themBrakes pull to one side when stopingRear bumper has a few small dents in itHas electric fuel pumpSteering wheel needs cover and is kinda chewed up1972 blue 4 speed Pretty much stock and orginalBody has a decent amount of rust including floor,fenders and door. Although stuff has been added to prevent more rust. Engine seems to run good but makes a pretty loud ticking sound at idle. Owner says that is the way it has been since he has owned it and put about 20k on it.Tranny is excellent shifts very smooth and solidBrakes work greatSuspension feel wonderful had the car up to 90 and still felt smoothNeed to go back to DMV and get everything taken care ofHas a nick on the front windshield other glass is good Front carpet is fair/poor Center Console is greatFan/Vent controls and heater work like they shouldAll Gauges work except for the fuel and clockDash has only a few minor cracks Drove it home about 60 miles and drove like a champ What do you guys think is the keeper Blue or yellow? Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/ Share on other sites More sharing options...
September 3, 200321 yr comment_48479 Should be an easy choice... always choose the chassis with less rust, unless the rust on one car is only on the outer body panels that can be easily replaced. In your case, I'd keep the yellow one..... Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48479 Share on other sites More sharing options...
September 3, 200321 yr comment_48481 The car with the least amount of BAD rust/rust through is probably the best starting point. Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48481 Share on other sites More sharing options...
September 3, 200321 yr Author comment_48482 Originally posted by 2ManyZs Should be an easy choice... always choose the chassis with less rust, unless the rust on one car is only on the outer body panels that can be easily replaced. In your case, I'd keep the yellow one..... No it is beyond the outer body. If it were just the outer body I would probley just swap it out. Seems like a decent amount of work either way I go. What is appealing about the blue one is everything is where it is suppose to be. The yellow one has been screwed with. Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48482 Share on other sites More sharing options...
September 3, 200321 yr comment_48483 No doubt! The tranny could fall out and the less rusty would still be a better deal!Plus that.....IT"S Yellow!! <my favorite Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48483 Share on other sites More sharing options...
September 3, 200321 yr Author comment_48484 Originally posted by Victor Laury No doubt! The tranny could fall out and the less rusty would still be a better deal! Plus that.....IT"S Yellow!! <my favorite The funny thing is both started there life light green Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48484 Share on other sites More sharing options...
September 3, 200321 yr comment_48485 Use my post of the pics of my parts car and base your decision from there. My parts car has to be the worst case scenario out there. Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48485 Share on other sites More sharing options...
September 3, 200321 yr comment_48488 Duuuuuuude, Thats unrecognizable.....did he try bondo-ing that thign? Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48488 Share on other sites More sharing options...
September 3, 200321 yr comment_48491 thats a disgrace!!!!! you may have won the title on this one. I wonder how he dealt with the fumes trying to weld galvanized metal...Man that picture is scaring the hell out of me. Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48491 Share on other sites More sharing options...
September 3, 200321 yr Author comment_48492 Ok guys looks like the yellow one is the keeper. Besides swapping the dash everything else looks like I can handle. I may even swap the tranny's Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48492 Share on other sites More sharing options...
September 3, 200321 yr comment_48499 when 2many tells you to keep the yellow ZROFL i have to admit though i would just swap out whats good off of the blue one and put it to the yellow one and keep from both any spares that you could use later one. Link to comment https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/#findComment-48499 Share on other sites More sharing options...
