I just picked up another 1972 240z yesterday after realizing the one I had needs alot of mechnical work like suspension and other saftey issue. I plan on swaping the good parts off one and putting it on the one I keep.
Which one do you guys think I should keep
1972 Yellow 4 speed
Body is really nice and straight very light rust issues no major dents
Car has a newely rebuilt L24 engine and runs awesome
Tranny is a little notchy but still works well
Brakes pull to one side when stoping
Suspension is shot and bottoms out all the time
Registeried in my name already and have the pink slip
Glass is perfect all the way around
Front carpet is decent
No smog equipment attached
New raditator
No key's to anything including the ignition which I start with any key
Heater core removed
Dash has alot of cracks
Center console is trashed
Side Windows need realining
Some aftermarket wiring on some stuff like the lights
Vent/ Fan controls don't really work
taillights have several cracks in them
Rear bumper has a few small dents in it
Has electric fuel pump
Steering wheel needs cover and is kinda chewed up
1972 blue 4 speed
Pretty much stock and orginal
Body has a decent amount of rust including floor,fenders and door. Although stuff has been added to prevent more rust.
Engine seems to run good but makes a pretty loud ticking sound at idle. Owner says that is the way it has been since he has owned it and put about 20k on it.
Tranny is excellent shifts very smooth and solid
Brakes work great
Suspension feel wonderful had the car up to 90 and still felt smooth
Need to go back to DMV and get everything taken care of
Has a nick on the front windshield other glass is good
Front carpet is fair/poor
Center Console is great
Fan/Vent controls and heater work like they should
All Gauges work except for the fuel and clock
Dash has only a few minor cracks
Drove it home about 60 miles and drove like a champ
What do you guys think is the keeper Blue or yellow?
https://www.classiczcars.com/forums/topic/7747-2-240zs-which-one-to-keep/
Should be an easy choice... always choose the chassis with less rust, unless the rust on one car is only on the outer body panels that can be easily replaced. In your case, I'd keep the yellow one.....
No it is beyond the outer body. If it were just the outer body I would probley just swap it out.
Seems like a decent amount of work either way I go.
What is appealing about the blue one is everything is where it is suppose to be. The yellow one has been screwed with.
Originally posted by Victor Laury
No doubt! The tranny could fall out and the less rusty would still be a better deal!
Plus that.....IT"S Yellow!! <my favorite
The funny thing is both started there life light green :)
thats a disgrace!!!!! you may have won the title on this one. I wonder how he dealt with the fumes trying to weld galvanized metal...
Man that picture is scaring the hell out of me.
when 2many tells you to keep the yellow ZROFL
i have to admit though i would just swap out whats good off of the blue one and put it to the yellow one and keep from both any spares that you could use later one.
