Posted September 4, 200321 yr comment_48568 I need one 14 inch minilite wheel. Also possibly four stock 14 inch wheels and hubcaps for a 73 240 if I can't find a single minilite. Unfortunately one of my front minilites came off at night and when I went back in the morning(at first light) to search for it, it was nowhere to be found. Thanks, Victor. Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/ Share on other sites More sharing options...
September 4, 200321 yr comment_48569 Do I dare to ask how one drives home in a three wheeled Z? Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48569 Share on other sites More sharing options...
September 4, 200321 yr Author comment_48572 Via AAA. Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48572 Share on other sites More sharing options...
September 4, 200321 yr Author comment_48573 AAA is a nationwide towing company in the US. Forgot you were from Australia. Victor. Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48573 Share on other sites More sharing options...
September 4, 200321 yr comment_48574 Just a point of interest, I lost a wheel from the boat trailer at about 80km/hr, and the wheel overtook the car, veered across the road, cleared a fence and came to rest nearly 200m into the local wetlands area. Is it possible you just need to widen your search area? A moving wheel can make it a hell of a long way. I hope your Z is ok.Cheers Chris Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48574 Share on other sites More sharing options...
September 4, 200321 yr Author comment_48599 Yes, I checked for at least a quarter mile before and after where the wheel came off and 70 to 80 yards each side of the road. Even looked in the trees. The only damage to the Z was a ground off ball joint(didn't scrape the control arm) and a flat spot on the brake rotor. The Z was quite controllable when the wheel fell off at 65 mph on a slow curve. Haven't checked the other lug nuts yet, but do plan on it. Emailed Minilite distributor in US and he said they only used the aluminum lug nuts for a short period in the 70's and does not recommend them. Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48599 Share on other sites More sharing options...
September 5, 200321 yr comment_48616 what kind of wheel u need the steel or the shelby mag? i have the steel one. Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48616 Share on other sites More sharing options...
September 5, 200321 yr Author comment_48650 After talking with the people at Minilite, I think I may just try to find another Minilite aluminum wheel and then use steel lug nuts instead of the old aluminum ones. That hopefully will prevent a recurrence of my problem. Thanks for responding. Victor. Link to comment https://www.classiczcars.com/forums/topic/7759-wheels/#findComment-48650 Share on other sites More sharing options...
